Results 1 to 9 of 9
Thread: Granular Chlorine instead of Bleach
    scubasteve's Avatar
    May 2009
    Houston, TX
    52
    Any problems using the rest of my bucket of granular chlroine (Zappit) before I start using Bleach. I will be implementing the other two B's today, beginning with baking soda. Just want to make sure the Zappit is not gonna screw things up.
    sS
    16,000 Gallon Inground Pool
    Hayward DE Filter
    Polaris 280 Pool Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Granular Chlorine instead of Bleach
    That depends on your CH reading. If it's reasonable, no problem.
    scubasteve's Avatar
    May 2009
    Houston, TX
    52
    Off the top of my head....I think I remember it being something like 250 or 300.
    Is that reasonable?
    sS
    Hayward DE Filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Your CH is right where it needs to be, I don't know that you want it higher....
    scubasteve's Avatar
    May 2009
    Houston, TX
    52
    The Pool Calculator Rocks! I love that it tells me exactly how much 73% Cal-Hypo to add instead of bleach. Did a test yesterday afternoon then made a few adjustments based on those results. Added a tid bit of zappit followed by some baking soda a while later. Before I went to bed (stayed up late helping my daughter study for finals) I did another test, everything was perfect. For some weird reason, I am excited to get home and test my water.
    Just one thing.....now you guys got me thinkin about a SWG
    sS
    Hayward DE Filter
    Jun 2007
    NC
    255
    Quote Originally Posted by scubasteve
    .....now you guys got me thinkin about a SWG sS
    Me thinks that you've got or are getting: the 'TFP/Clean Water Geek' syndrome! 8)
    I think that SWG's are one of the best things since sliced bread!
    The only bad thing that I can say about ours is that the PH rises, but that's taken care of with a little MA! Just rember that testing and additional shocking may be required
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    scubasteve's Avatar
    May 2009
    Houston, TX
    52
    Quote Originally Posted by fuzzy_dba
    I keep seeing "MA". What does that mean? I couldn't find that in the Pool School write up.
    sS
    Hayward DE Filter
    MA is muriatic acid.
