Results 1 to 9 of 9
Thread: Need plans for deck
    jenmoran99's Avatar
    Aug 2016
    Ponchatoula la
    3
    Need plans for deck
    ]Attachment 52916We're looking for designs/plans for a floatingdeck that we saw on popular mechanics. We love the design but cannot find plans or reach anyone. Any ideas. We have a 24"x52" above ground Heritage pool. The deck in the photo is what we would like.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,610
    Re: Need plans for deck
    Your pic did not show up on this post.
    Do a search for the different builds. There was one not too long ago where he built his own deck and it came out great. I don't think he had plans really. They just built it to fit the pool.
    Your best bet may to be find a few woodworkers and have them take a look at what you want and see what they say.
    Good luck!
    Larryh86GT's Avatar
    Jan 2015
    Western New York
    93
    Not sure what a floating deck is.
    Coleman 16' x 48" power steel pool.
    jenmoran99's Avatar
    Aug 2016
    Ponchatoula la
    3
    Can you see my profile picture? Its that one.  We have searched everywhere. We need a cost est. also.
    Jun 2016
    Kansas City MO
    23
    Are you building it yourself or using a deck contractor? An experienced contractor should be able to draw up plans and an estimate. I'd have concerns building a floating deck that large, but it probably depends on local soil conditions and building codes.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,827
    I second the concern for having a floating deck that high off the ground and that large esp when built around an object like a pool that would easily get damaged it the deck shifted. You are in the south though where it doesn't freeze so you don't have to worry about frost heaves. Like Josh said tho check with local codes.
    To Larry a floating deck is a deck built with pads on top of the soil as opposed to having posts dug out and set into the ground. So in theory once built a floating deck could be picked up and set down and it wouldn't notice.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    2kCougar's Avatar
    May 2015
    Albany, NY
    35
    Have you looked at these? http://www.menards.com/main/building...cks/c-9660.htm
    Our 24'x16' deck has 12 10"x4' concrete piers. Might be overkill, but it's not going anywhere. The 3' landing outside our slide is on piers and keeps sinking.
    24' Radiant metric semi-inground, Hayward S180T92S, 8/2015 install, TF-100
    Dec 2015
    Mt Airy/NC
    13
    I had an existing deck from the rear of my house, and installed the pool about four feet from that deck. Then I went on Lowes web site, where they have a 'design your own' deck plans. It's a program where you fit in your dimensions and the style you want, and the program will set up a drawing of the deck and give an estimate of what lumber is needed and a price. My was a small rectangular access deck connecting the main deck to pool. But I built it as a floating structure that is independent of the main deck and pool. I believe Home Depot also has a design program available. Good luck!
    17k, 27'AG, Sand, 2spd Pentair, Hayward Aqua-trol salt system, TF100 tst kit
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    As a retired porch and deck licensed contractor, I recommend checking with both the state and local building departments to see what is required in: a: building any deck and b: building around a pool. They are not necessarily the same. Pool decks typically are the most expensive to build since the number of posts required to accommodate the pool curve is higher on a per square foot of deck cost. Remember that if you don't have it inspected your insurance underwriter may reject any claims that might arise.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
