Thread: I need a new filter.
    Jun 2014
    Central Florida
    36
    I am currently using a Hayward De3600 and the filter housing is cracked. What are some recommendations for a suitable replacement and where I could get one at the best price? I would prefer a filter that would connect to the fittings that are already installed, so I just have to screw in the filter without having to adjust or replace anything else.
    This one looks about right.
    Hayward Pro Grid DE2420 Inground de Diatomaceous Earth Swimming Pool Filter | eBay .
    The 3600 is 72 gpm, maybe a little more than needed for my pool?
    This one is 24 sq. ft and 48 gpm, but that should cycle through my pool in 8 hours. 48*6*8=23,040
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: I need a new filter.
    I would never go smaller with a filter, at least the same size or bigger
    Apr 2015
    tucson, arizona
    1,139
    The Hayward pro-grid series bottom tank half is the same for all sizes, so the plumbing will line up if you stay with this model. The difference is in the top half. I agree with the Cowboy stay at least the same size or larger
