Thread: Suction side water leak
    Jul 2014
    Houston, tx
    4
    I feel dumb for asking, but is this possible or common? Here's the background.
    I've noticed water loss all summer long. There was a pretty big crack near the skimmer - which I had patched. But the water loss is still there. I did a bucket test and it quickly confirmed I was losing significant amount of water while the pump was running. And there was a small amount of air bubbles in my pump when it was running. When I turned the pump off for about 24 hours - no water loss.
    I turned the Jandy valve for one skimmer off today. Surprise, surprise - no water loss (24 hours and running). Fortunately, this is the skimmer closest to my equipment pad.
    But everything I read about suction side leaks deals with air leaks. I don't see any water leaks above ground but I'm going to dig just below the surface near my equipment pad to see if there's anything noteworthy. Any other thoughts on where else to check before bringing in some hired help?
    Thanks!
    22,000 gallon kidney shape IG, attached raised spa, Pentair WhisperFlo 2 hp for pool, Pentair WhisperFlo 2 hp and 1 hp for waterfalls, Pentair FNS Plus DE 60 filter, heater, Silencer air blower 1.5 hp for spa jets, Pentair MiniMax plus heater, Booster pump for Polaris
    38,295
    Re: Suction side water leak
    More water loss with the pump on generally points to a return side leak, not a suction side leak ... so the isolation of turning the skimmer off and not losing water with the pump on is puzzling to me.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    That's what I'm thinking too.
    Solar Blanket, Well Water, Borax Added. 68
    Dec 2014
    Santa Ana, CA
    523
    coincidence? may be it was leaking to waste all this time?
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jul 2014
    Houston, tx
    4
    Whew, glad I'm not the only one. I am gonna see what happens the next two days with the skimmer off. Usually I will see significant water loss after that amount of time.
