Thread: Calcium deposits
    Jun 2016
    Kansas
    5
    Calcium deposits
    Does it seem appropriate that I should have to deal city my plates every other day? (due to the amount of gunk that builds up that fast).
    What causes the calcium build up and is there anything I can do to slow it down?
    Oops, that was supposed to read "decalcify", posting from my phone and auto correct is rude!
    Kristi, Kansas
    15,000 gal intex, above ground
    Sand filter, SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Calcium deposits
    It is called scale and yes it can be prevented. Enter all your test results into PoolMath and it will give you a CSI score. Keep that number negative to prevent scale. Adjust PH and TA to change the number.
    More here, Pool School - Calcium Scaling
    Jun 2016
    Kansas
    5
    Quote Originally Posted by pooldv View Post
    Ah, yes, thank You! I knew I'd seen it somewhere!
    And just to clarify, this is in relation to the scaling on the metal plates in my SWG?
    Kristi, Kansas
    Sand filter, SWG
    DFW, TX
    24,502
    Scale is scale in the SWG or in the pool. It is all the same stuff. If the SWG still scales at say -0.3 then you can drop it -0.6.
