Thread: How to Lower TA with a already low PH
    Aug 2016
    Merrick NY
    10
    Hi all,
    just did my first test with my TF-100. What an amazing kit! Below are the results:
    FC 4.5
    TC 4.5
    PH 7.2
    TA 100
    CH 250
    CYA 80
    Salt 2100
    Borate 15
    I would like to lower my TA, without lowering my PH anymore. Also I would like to raise my borates, to replicate mineral springs that I used to use. I assume I would areate using my waterfall to bring up the PH if I were to use muriatic acid to lower the TA?
    Thanks
    Jason
    33k gal, SWG vinyl IGP, free form lagoon, 8' deep end 4' shallow end, Pentair IntelliFlo VS 2hp, AutoPilot SWG, DE filter, Manifold with RC-35/22 cell, Pool Pilot Digital, Gas heater, waterfall, 7 wall returns, 2 bottom returns, 2 skimmer baskets
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: How to Lower TA with a already low PH
    If your PH is stable then there is no need to lower your TA. If PH we rises then lower your PH with acid which will a.so lower your TA. If your PH is stable then go ahead and add borates when you are ready.
    Aug 2016
    Merrick NY
    10
    Wouldn't adding borates also raise my
    TA?
    DFW, TX
    24,497
    Use the Effects of Adding Chems at the bottom of PoolMath to tell you what chems will add to the pool. Muriatic acid will also lower it.
