Thread: Painted over plaster cracking off, inground gunite pool
    Aug 2016
    Lake Oswego, OR
    1
    Bought a home with an old pool this year. The pool had been replastered about 2 years ago but because of a foot print the owner decided to paint it. The paint has bern chipping off with dark plaster underneath which is unslightly, but today I noticed about a 12" section in the deep end where both paint and plaster had chipped off in a crescent shape, about 1/8" thick, several pieces. Nothing has been dropped there. Am I doing something wrong, i.e water chemistry or is this likely a bad plaster job?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Painted over plaster cracking off, inground gunite pool
    Welcome to TFP
    Pictures Pictures Pictures. Test results and pictures. Overall pool and the damaged area.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    Please add your pool info to your signature, more here on what to add and how to do it, Pool School - Read This BEFORE You Post
    Yes, several sets of test results would be helpful. It is possibly a poor plaster job or more likely poor management of water chemistry. Failure to properly manage water chemistry can cause plaster to fail in 5 years or less. With properly managed water chemistry plaster can last 15-20 years or more.
