Thread: Pool heater hookup
    Aug 2016
    Twin Lakes
    1
    Pool heater hookup
    Hello all. Newbie here. I was just wondering about hooking up the 1 1/2 inch filter hose to my heater. I have the Hayward universal H150 which, in the manual, says it can accommodate 2" or 2 1/2". Then says to not have any other flow restrictions from the outlet other than inline feeders which I do have. I plan on pouring a concrete pad next spring and will then do all pvc hookup, but i have all the parts already needed to hook up the 1 1/2 and was curious if this would cause too much restricrion. Thank you
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Pool heater hookup
    Welcome to TFP!
    Please add your pool info to your signature so that we can better help you. More here on what to put in your signature and how to do it, Pool School - Read This BEFORE You Post
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    It is perfectly fine to use 1 1/2 PVC hooked up to this unit. Use a 2" to 1 1/2 reducer, glued and inserted into the heaters union fitting.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    May 2016
    Rochester, MA
    32
    Just an FYI, depending on how you plan to install your heater and if you are using any valves, you can use a Jandy never lube valve as a reducer from 2" to 1.5". It's what I did with my heater.
    18 x 36 In ground vinyl pool 8' deep end
    Hayward EC65 DE Filter
    Aquacal SQ225
