Thread: Turbo cell problem?
    Apr 2016
    Punta Gorda Fl
    11
    Turbo cell problem?
    Hey all...have a question. On my saltwater pool panel I am showing a no flow light. I've tried to reset it, I unplugged it and replugged back in, etc...light still comes back on. So I removed the Hayward turbo cell and cleaned it. It actually had zero build up but I did the acid clean out anyways. I also checked that switch that is above the cell.....not sure how it is supposed to work but it looked clean and the two pieces were not fused or anything. Put it all back together and no flow light is on still.
    So any ideas on whats next? I have no idea how old any of the components are, we bought the house approx 5 months ago.
    Jun 2011
    Long Beach, CA
    2,790
    Re: Turbo cell problem?
    Double check that there is enough flow through the cell. Has the pressure on the filter risen?
    Make sure the arrow on the flow switch is pointing towards the water flow direction.
    Inspect the cord for damage.
    If all that passes, buy a new flow switch and hook it up electrically to the board but do not plumb it in yet. With the new flow switch hooked up and the pump running, keep the flow switch closed to represent water flowing through the switch. If the flow light goes out, install the new flow switch.
    Apr 2016
    Punta Gorda Fl
    11
    I was going to bring in the cell to have it checked out tomorrow...as for the filter pressure, not sure, good question. As for the switch direction, I didn't know there was even an arrow, so I will check that out tomorrow.
    I will get a new switch and do that troubleshooting you suggested.
    Will keep you updated, thanks for the help.
    Apr 2016
    Punta Gorda Fl
    11
    Wound up being the switch...the pool shop let me bring it home and troubleshoot with it...tested it out, works great now....it was a bit pricey at 80.00 but its working fine now, thanks for the help.
