Thread: UP goes the Ph, ready for any future TA reduction
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    I don't even currently have a high TA, but after getting it down I had to play around a little.
    This didn't turn out as impressive as I planned, but I also only used a bunch of spare stuff left laying around for the most part. It uses four venturi valves I paid $1.63 each for on E-bay but had to wait a long while for shipping from China to get them so cheap. I also needed a Polaris universal fitting only because it's where I intended to put it. It doesn't seem to seat well and makes an awful noise, but since I don't really need it right now I didn't bother with it.
    I think only two venturi valves would have maybe worked better, or at least make a more impressive cloud of bubbles
    IMG 03781 - YouTube
    IMG 03791 - YouTube
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    JoyfulNoise's Avatar
    May 2015
    13,171
    Re: UP goes the Ph, ready for any future TA reduction
    That's neat! Great work.
    Matt
    May 2015
    Mount Cheaha Alabama
    250
    Very nice.
    I built a modified venturi based off a design for this product http://www.hendersons.co.uk/wms/airmaster_venturi.html
    Very easy to construct with some PVC board, glue and a couple drill bits
    This is a 3/4" test that would not work in a back-pressured setup but screams bubbles in front of a return jet. I have a scaled up 1.5" version that will raise pH in a hurry
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
