Thread: Limestone dust in pool... effects? Mitigation?
    Nov 2014
    Austin, TX
    34
    Had our pool put in a couple of years ago, FINALLY got the pool builder to send the stone masons back out to fix some legacy problems from a worker who was too aggressive sanding/grinding the spillover stones (turned them into anything but squares). It occurred to me that the sanding and grinding to true up the stones (4, about 15x15") will put limestone dust in the pool (deck is Leuders limestone).
    Is this a problem given that Limestone is largely comprised of calcium? We have hight mineral water here in central austin, with our Calcium levels typically around 275ppm. If it is a problem is there anything I should do to mitigate it?
    I lowered the PH to around 7 the day before they did the work, which I'm assuming is better for breaking down the limestone dust more quickly and preventing it from solidifying anywhere on the plaster, etc. Is there anything else I should do? Monitor PH closely? Reduce PH below 7 for the next week? Empty the filters?
    Sorry if this is the wrong forum for this, wasn't really sure where to post.
    Thanks!
    Rick
    Jul 2015
    Central Valley CA
    1,109
    Re: Limestone dust in pool... effects? Mitigation?
    Someone will chime on the chemical side but my take is that dust even fine dust is a fairly large particle. Keep the pump running brush as much as you can to keep it in suspension and clean the filter.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, moving it to the filter is the best thing. Keep an eye on your CSI, PoolMath will give you the number, keep it between- 0.3 and 0 to avoid scale. Otherwise, you are fine.
    More here, Pool School - Calcium Scaling
