Thread: A-Frame ladder install
    TexasHeatWave's Avatar
    Jul 2016
    Cypress, TX
    14
    Just curious to know how yall installed/mounted your ladders to your pools. I have a 27'x52" Yorkshire metal frame above ground pool and have been having a few issues with the ladder not being stable. Can yall post pics and maybe help a fella out as to the best way to mount an A-frame ladder. Reading through the directions I believe that is said to drill through the top of the ladder and into the rail of the pool and secure it that way.
    27'x52" Yorkshire Metal Frame Pool (19,324 gallons). Pentair Dynamo 1.5hp pump/22" Sand Dollar Filter (250lbs).
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: A-Frame ladder install
    We didn't do anything with our rickety ladder except be careful. We replaced it after a couple years with a set of stairs that had a locking gate; the whole setup was so much more stable.
    Then this spring we had a deck built.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
