Page 1 of 3 123 LastLast
Results 1 to 20 of 59
Thread: Muriatic acid scares me
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    Had to add some hydrochloric acid to pool to lower the ph that naturally likes to sit at 8 for some reason. Thst acid is pungent and scary. I really don't like handling it and mixing it with water. How does everybody else feel?
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Muriatic acid scares me
    Yes, it is strong stuff but stuff that you can use safely with a few common sense guidelines. You can wear goggles and gloves. Don't mix it with water ahead of putting it in the pool. Some around here will just hold the entire gallon in the water near a return (with pump on!) and tilt it so it pours an estimated amount. Always brush the pool where you put it in so to mix it well in the water. Always stay upwind from it and avoid walking with a open container in case of trips/falls.
    Jun 2014
    15,153
    It's a chemical that demands respect, there's no doubt about it. But it's purpose and usefulness in pool chemistry can't be argued. It's perfect for lowering pH (and TA), and comes-in handy for other uses at times (i.e. cleaning scale). As with any volatile product, safety and respect for the item being handled are paramount. Not that we do it 100% of the time, but we should always remember to protect the eyes, skin, and watch the wind direction when we are around the fumes. Those safety items are critical. I've messed with the dry acid back in the day, and it was just too much of a pain for me to mess with. Also keep in mind there are lower strength muriatic acids out there. So even though you might pay a little more in the long-run by using twice as much, those lower strength MAs aren't quite so potent.
    LittleTagAlong's Avatar
    Jun 2016
    Amarillo TX
    119
    I carry the Muriatic Acid out to pool in its closed container. Then put on my mask and gloves. After that, I use a Home Depot 5 gallon bucket and scoop up about a gallon or so of the pool water. Then standing upwind of the MA, I carefully pour required amount in to measuring cup and VERY slowly add that to the water in the bucket. I stand to the side of the return and slowly add the mixture to the pool, taking time for it to mix. I haven't been brushing after, but probably should. When I am finished, still with mask and gloves, I rinse bucket and measuring cup in return flow of pool.
    AG, Intex 18' x48" Easy Set pool( =/- 5455 gal)
    Intex SF80110 sand filter & SWG ECO 7110, Hayward AquaCritter
    Well water, location is north Texas, usually up from late May to Oct.
    Taylor TF-100 test kit, TDS Digital Salinity meter and Taylor salt kit
    Apr 2013
    Sacramento, CA
    2,769
    1)Store in an open location away from the chlorine.
    2) pour by holding right over the water and slowly pouring in a small amount right in front of a running return. I just estimate from the jug.
    Many HD sell in two strengths 14.5% and 29% In my HD (Rancho Cordova, CA) they are together in the back of the garden section. I buy the strong stuff, you can get the weaker stuff Pool Math will do the noodle work.
    Aug 2013
    Dallas, TX
    78
    I didn't know that you should brush the area where it is added. What can happen if you don't?
    23,000 gal. IG gunite pool, DE filter, elevated spa with spillover, Polaris 280 cleaner
    Jul 2014
    Hope Mills, NC
    567
    I just pour it in right in front of a jet. No big deal. If you spill it rinse quickly, don't breath the fumes and whatever you don't pour any on the grass, it kills it very quickly...not that I would know. Acids don't really need to be stirred into the water to work, they work by adding or removing ions, which happens at the speed of electricity.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2016
    West Bloomfield, MI
    713
    I'm careful with it, but it doesn't scare me.
    I bought some DE to help my sand filter however, and that stuff wigs me out. It's sold in a loose bag inside a loose box, that basically says don't touch it or breathe it. Apparently it's banned by some municipalities...?
    I don't even like walking too close to that box.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    May 2016
    MD
    195
    Quote Originally Posted by Griswald View Post
    Good to know I may just brush anyways to make sure nothing silly happens
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Aug 2015
    Grandy, NC
    135
    Also do not combine in any manner with bleach. Even suggest you store away from each other. I forgot to rinse glass measure cup used for bleach and almost used to dose with MA. Fortunately, I sniffed the cup and rinsed thoroughly.
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Jul 2014
    Liverpool NY
    121
    Bleach and muriatic acid will liberate chlorine gas and if you inhale it that might just be your last breath.
    Jul 2012
    Dallas, TX
    179
    I use this for both Bleach & MA dosing. I follow the "upwind" advice from other members here. I always add doses in the deep end of the pool in front of one of the Return Jets.
    Then I rinse the measuring cup in the shallow end.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Jan 2012
    7,351
    You want to brush the area you've poured the MA in *just in case* some settles in one spot and it can mar the finish of your pool.
    May 2015
    Fullerton, CA
    636
    I was told to add the acid to water in a 5 gal bucket. I put about a gallon or more water in the bucket, pour acid into a plastic measuring cup and then slowly pour into the bucket with water. I then pour the bucket nto the deep end slowly in front of a return. when the pump is going. There are a number of safe methods.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    213
    Am I only the one who pours from the bottle and just feels it out for how much they are adding?
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
    Oct 2010
    michigan
    284
    Pour and estimate in front of the return.
    Stretch my arm as much as possible and slowly pour in front of the return. Stay away from the fumes.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Rockland County, NY
    52
    Acid is heavier than water. Even if you pour it over the return jet, some will find it's way to the bottom before it is all thoroughly mixed in your pool water. Therefore, it is important to get the acid mixed and diluted as much as possible before it can sit on the pool bottom for any extended period of time. This is particularly important if you have a vinyl liner, since they don't take kindly to drastic changes in lowering levels of ph. Use the pool brush to help mix it in, and brush the sides as well as the bottom.
    22,000 gallon ig vinyl solar heated (panels and cover) zeolite filtrate
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I pour only full bottles of bleach at a time, what's a couple extra ppm between friends? And I estimate about a quart at a time of muriatic acid straight from the bottle in front of a return. Downwind. Bottle floating so the opening is close to the water surface.
    Jul 2012
    Dallas, TX
    179
    Good advice, diluting w/water; acid heavier; settling to bottom. I haven't seen any stains at the bottom of my Gunite pool but I think I'll switch to the 5-Gal dilution method; like the idea.
  20. Back To Top    #20
    Jun 2016
    Western Connecticut
    47
    I put on goggles, thick rubber gloves, and a mask, and then carry the closed bottle of the liquid to the pool (not putting the bottle down on the patio). I use a 2 quart measuring cup that I wrote "Acid Only" in big letters all over it in marker. I stay upwind and pour the amount I need and then put the measuring cup close to the water as I pour it in. One time I got a whiff of the fumes and I started choking immediately. Probably not the best thing to do.
    32,500 gallon in ground Gunite/White Plaster, Pentair Cartridge Filter, Pentair Propane Heater, Pentair Racer robot cleaner
