Thread: leaks in various places
    Apr 2009
    Central Jersey
    I am a new pool owner so I am not sure if this is a problem or not. When the pool was first installed all seemed fine. Now there seem to be several connections between the filter-pump-chlorinator that leak, sometimes a lot and once one of the hoses came completely undone and we ended up losing a lot of water. Question, is it normal for things to become loose from the vibration, thereby requiring periodic checks or should I have the installer come back and tighten things up?
    15K Gal, 18 x 33 AG oval, 1 1/2 HP Proline Pump, 22" sand filter, Auto chlorinator, Pool Rover JR.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Re: leaks in various places
    Those fittings can start to leak over time for all kinds of reasons. Vibration may wiggle it loose. It may contract and expand from temperature. Or O-rings may start to deteriorate. But they're all usually pretty easy to service. If you can take a few pics of the ones that are giving you problems we'd be happy to help you address each one individually and save yourself the service call.
