Results 1 to 13 of 13
Thread: Hello from chicago
    DLR's Avatar
    Aug 2016
    Island lake
    22
    Hello from chicago
    I'm 43, Father of 4, married to a great women. I was given a pool a few years ago, wasn't sure of the condition it was in but the heat wave this year drove me to pull it out and put it up in a week. turned out to be in great shape was able level it within a half inch. Very proud of the fact that I have never owned a pool and turned out so awesome, Its like walking around on my patio. going back to the never owned a pool before, I will need a lot of help until I can get this chemistry under control. any help will be greatly appreciated.
    27' round above ground with 52" wall, calculated 18,500 gal., 1.5 hp Hayward power flo lx pump with Hayward pro series model S-210T sand filter, taylor K-2006 test kit
    Jun 2014
    15,059
    Re: Hello form chicago
    Hello and welcome to TFP! Best thing we can advise at this point is proper water testing. The proper test kit (i.e. TF-100 or Taylor K-2006) is the foundation of your pool care. Why these kits? We've learned through extensive practice that you cannot reply on pool store testing, test strips, or simple over-the-counter kits. Personnel training, lighting, and product sales influence accurate testing too much. In addition, simple test kits do not read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need. If you do not have a TF-100 or Taylor K-2006 test kit, it should be your #1 priority. TFTestkits.net
    Great to have you with us.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Welcome DLR. Pat is right, you will not regret the test kit investment. Once you get the kit caring for the pool will be easy, so easy one of those 4 kids will have a new chore
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    DLR's Avatar
    Aug 2016
    Island lake
    22
    Re: Hello from chicago
    I bought a pool master 5 way test kit to get me started I will pick up a better one after the season is over. I just put out 2k to get the monster put up.
    Pool Tool's Avatar
    May 2014
    757
    You are in a somewhat unique position of having a known CYA level - zero (there is zero in tap/well water). This gives advantages others don't have. CYA is generally the 2000 pound gorilla in the room that the pool stores dismiss. Be mindful of your CYA additions and you will be able to manage your pool effectively. Most pucks will add CYA, since you are close to the end of the season this may or may not cause you issues if you use the in-line chlorinator.
    CYA is compared to sunblock for your free chlorine, aka FC. It helps protect FC from sun's UV rays by binding to it. This bind renders some FC as ineffective so your target FC levels have to go up as CYA rises. For folks that use a lot of powdered shocks or dichlor/trichlor pucks, the CYA levels can rise quickly and require prohibitive FC target levels so it needs to be managed properly. The recommended test kits allow accurate testing of your CYA (and everything else) whereas the pool store often lacks.
    The downside of no CYA is that all your FC will be burned off by the sun in a matter of hours. Additionally, FC in pools without CYA is very damaging to equipment and people even at low levels.
    I am not trying to overwhelm you, but rather hit a few high points to save you some grief potentially. Read all you can in Pool School and ask questions. There is a lot of information and expertise here and I believe the only 'official' cost is pictures of your setup. Enjoy that pool.
    DLR's Avatar
    Aug 2016
    Island lake
    22
    I don't have well water I used city water, but you are correct the second day after I filled the pool the test showed no chlorine as I was focusing on balancing ph and ta since my ta reading is super high. I put 3 hth ultra chlorine pucks in the chlorinator and poured a pound of shock in the skimmer tested it a couple of hours later everything was almost perfect fc 2 ppm ph 7.2 but the ta is still off the charts at 300 ppm.
    Pool Tool's Avatar
    May 2014
    757
    TA will affect your pH rise, but it is generally the last item we recommend worrying about. FC and CYA should be your first focus, IMO. The only real effect of high TA is rapid pH rise. Fortunately a little bit of muriatic acid will lower both pH and TA. Sounds like you have a good handle.
    DLR's Avatar
    Aug 2016
    Island lake
    22
    update: pool chemistry is going in the right direction FC 1.5 PH holding at 7.2 because of the aeration trick with the TA dropping down to 220 with over 2 gallons of muriatic acid added over the past 2 days.
    Apr 2013
    Sacramento, CA
    2,769
    You just need to understand that the pucks raise the CYA. That means it takes more chlorine to maintain the same level of protection. Read pool school ABCs of pool water chemistry.
    DLR's Avatar
    Aug 2016
    Island lake
    22
    hello I'm back after a mild winter. wish me luck on my first full season. I will not be using any HTH, can some recommend a particular brand of bleach for chlorinating
    wjr75's Avatar
    Jun 2013
    IL
    836
    Looks like there is a The Great Escape in Algonquin. The one in Naperville sells the 12.5% liquid shock for $10 per case of four gallons. Should be the same price. Also the Muriatic acid is $5 per gallon. Menards in Crystal Lake may be an option..they have buy one get one free sales sometimes.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    DLR's Avatar
    Aug 2016
    Island lake
    22
    Thank you, I will look into that.
    DLR's Avatar
    Aug 2016
    Island lake
    22
    I pulled the plug on the pump that came with the pool. it was making a god awful whining noise when it was on, I found a great deal on amazon for the same pump with a 1.5 hp motor instead of the 1 hp the old pump had. and I also ordered a taylor k-2006 test kit to start this season off on the right foot.
