Thread: CYA up to 60. I'm now switching to Bleach - Am I OK?
    Sep 2015
    Bloomington IN
    27
    Bought the house about 1 year ago. Did what the previous owner did (pucks in skimmer).
    I now understand CYA and have a good test kit. My CYA has started to creep up to 60. I stopped the pucks, and started using Bleach.
    I don't want to mess with a major drain at this point (I drain some for winter).
    Am I OK at 60 CYA now and using Bleach, or do I need to do something else? Does keeping the cover on help? Anything else to keep the CYA from getting an higher?
    FC- 6
    CC- 0.5
    PH- 7.5
    TA- 120
    CH- 130
    CYA- 60
    Bill
    14000 Gal, Vinyl Lined Pool, No salt
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: CYA up to 60. I'm now switching to Bleach - Am I OK?
    If you are only using bleach and no pucks and no "shock", your CYA won't go up any more.
    60 CYA is high but not unmanageable. Pool School - Chlorine / CYA Chart
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
