Thread: Shaft/Mechanical Seal Replacement Interval?
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    As a preventative measure, should the shaft seal be replaced on some type of interval?
    I understand different variables could apply such as water chemistry, poor priming, amount used, location, etc. I've had pumps before where I waited too long and the bolts sheared off or damaged seal plates, etc. so I had to replace the pump motor anyway.
    40x15 IG, 19,000 gallons, Taylor K-2006C, Intellichlor IC40, Pentiar 1.5 hp Intelliflo VS, Pentair 420 Clean/Clear Filter, Speedstir, Stonescape - french grey, Travertine Paver decking, Completed August 1, 2015.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Shaft/Mechanical Seal Replacement Interval?
    As long as it is not leaking there is no need to replace the shaft seal.
    Love TFP? Become a
    TFP Supporter!
