Results 1 to 9 of 9
Thread: hth 6 way test strips
    Aug 2016
    Ephrata Pa
    4
    Hello everyone, I am trying to learn and understand the different color charts that are on the hth 6 way test strips box. I searched the web and found info on most of the ones listed i.e. Guideline values: (FC) Free chlorine: 0.5-1.5 ppm (mg/l) , pH figure is 7.2 – 7.6. (TA) Total Alkalinity 80 ppm and 120 ppm., & (CYA) Cyanuric acid:0-20 ppm (mg/l) however, the one on the top of the list which is TOTAL HARDNESS (TH) ppm. is a mystery. after searching the web I know it has something to do with the hardness of the water. but I can't find what the reading should be, i.e. 100 ppm or 200 pmm or ? can anyone help me. Thank you
    Purchased July, 2016 Intex Easy Set, size of pool 13' X 33 " above ground, vinyl, Krystal Clear Model 603 Filter Pump, single speed, Dual Suction Outlets, Filter Cartridge ( 29000 ) Filled pool by garden hose, apx 1,600 gallons. Testing with hth 3 way test strips
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: hth 6 way test strips
    Welcome to TFP.
    For a small seasonal vinyl pool, there is no need to worry about CH (calcium hardness) unless the fill water was crazy high, which I don't think it is in your area.
    e: Tim is right, as always. I saw HTH 6 way and read as:
    Completely glazed over "test strip".
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Check out our Pool School - Guide for Seasonal/Temporary Pools
    Even for a seasonal pool, test strips are almost worthless. They read in too wide a range and are no where near specific enough for pool care. You should be able to pick yup a decent 2 way test kit (chlorine & pH) at WalMart for less than $10.
    Support the site
    Aug 2016
    Ephrata Pa
    4
    Thank you tim5055
    I took your advice and purchased hth 3 way test kit, at Walmart. the pH level showed 7.5 which was good, according to the directions, however, the Cl Br side remained clear, so my question is, does clear show no chlorine level in my pool?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Yes.
    What did you come up with for steps 2 and 3 of the article Tim posted?
    Aug 2016
    Ephrata Pa
    4
    Hello Mr Bruce
    I am not sure what you mean by steps 2 and 3 ?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    From the link Tim posted above:
    "Step 2
    Using the chart in your owner's manual, determine how many gallons your pool is. You may also be able to find this information on the manufacturer's website or you can use the Pool Volume calculator in Poolmath.
    Step 3
    For this step you will need Cyanuric Acid (CYA) to help protect the chlorine from the sun. This too can be found commonly at the local MegaMart sold in 3lb or 4lb containers. Using the PoolMath calculator add enough CYA to raise your level to 40PPM. With this being a “fresh fill” your CYA level will be zero to start with, so there is no need to test at this point."
    The HTH 6-way kit includes a test for CYA, but the 3-way kit does not.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Aug 2016
    Ephrata Pa
    4
    Hello jeffchap
    I think maybe your on the wrong topic, for on tim5055 post, on this topic, there is nothing about steps 2 & 3
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    Quote Originally Posted by tim5055 View Post
    It's in the link to Pool School in this post. Do you not see the link? Click on the blue underlined words.
    Pentair IC40 SWG
