Thread: Need advice!!
    Aug 2016
    Stonewall
    2
    Need advice!!
    I have a 24'52" above ground pool,I've just started filling it and there's about 2' of water in it,I noticed a dent in the side behind a wall support, after a little checking I found a paver that was just a little high so I tapped it down and it worked but I cracked the block,my question is will it be OK to leave it and continue filling the pool??
    I have and above ground 24'52" above ground paradise pool
    Dec 2014
    Santa Ana, CA
    523
    Re: Need advice!!
    Welcome!
    pictures would help- no one from here was there and it's hard to describe such problems in words.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Aug 2016
    Stonewall
    2
    Re: Need advice!!
    I will get some pics in the morning. Thank you for your response!!
    Aug 2016
    Toronto
    2
    Re: Need advice!!
    It will be better if you fix the dent now itself.. The dent may become large within few days. Prevention is always better than cure
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Need advice!!
    You will need to replace the block. A broken block will not provide the support needed and may sink as the pool fills with water.
    Love TFP? Become a
    TFP Supporter!
