Results 1 to 9 of 9
Thread: New pool owner needs help!!
    Aug 2016
    Bakersfield
    5
    Just purchased new DE filters after unsuccessful shocking treatment. After installing and adding 5lbs of diatomite filter aid my pump pressure increases 20psi. What do I need to get my psi back down to normal range
    15000gal plaster pool defilter
    Dec 2014
    Santa Ana, CA
    523
    Re: New pool owner needs help!!
    Quote Originally Posted by Sserna5174 View Post
    Welcome!
    Please specify more details about your equipment (model #s for pump & filter at least) and post some pics of the plumbing to get specific advice. You stated 'filters' - how many? I have DE filter and it's only 1 and it is not even the biggest in the series.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP!
    Most filter problems are really water chemistry problems. Most water chemistry problems result in algae. Algea clogs up a filter faster than anything. To kill algae we follow this process, SLAM. To perform a SLAM you need a good test kit. I use theTF-100 from TFTestkits.net. it is the best value, here's why, Pool School - Test Kits Compared
    Do some reading in Pool School
    ABCs of Pool Water Chemistry
    Pool School - Getting Started
    Add you pool info to your signature as shown here, Pool School - Read This BEFORE You Post
    Aug 2016
    Bakersfield
    5
    Sta-rite 1hp pump model p6e6e-206
    Wet industries capital vertical grid d.e swimming pool filter model wa-52 (10 total grid filters)
    Aug 2016
    Bakersfield
    5
    Dec 2014
    Santa Ana, CA
    523
    Let me see if I got the sequence correctly:
    - you purchased and replaced internal filter grids
    - then you added DE filter media to the skimmer and noticed your filter pressure is unusually high at 20 psi.
    What pressure did you expect? I'm asking because my filter normally runs at that pressure.
    Did you notice what pressure it was running at before you added DE media but after you assembled it back? If it was unusually high I'd open up the filter and recheck if the internals are assembled correctly.
    The filter needs to be bled of air before DE is added for proper DE distribution.
    Aug 2016
    Bakersfield
    5
    Psi increased from 12psi to 30psi. Do you recommend that I back wash and rinse filters and let it circulate before I add DE?
    Jul 2016
    Oviedo, FL
    13
    How do you know that you had to physically change the filters? Did you pull them out and find issues? I'm a new owner too and from my understanding those things can be tricky to install correctly.
    IG Plaster 11948 gal pool; Pentair FNS Plus FNSP-48
    Century Centurion Pump - looks like 1 HP?
    TF-100 Test Kit
    Spa w/ overflow to pool
    Aug 2016
    Bakersfield
    5
    Found a few holes on the grids
