Thread: Pump pumping air on start-up
    Mar 2008
    Central VA
    328
    I'm a member here, but my buddy isn't...he has an inground pool with a Hayward "Super-Pump"(?) and I know he has a sand filter...
    anyway, he's just opening his pool this season and he says the pump is pumping air into the pool, so that it creates bubbles/foam. He's had it happen before, but took the top off the pump and made sure his gasket was okay, and the problem stopped on that occasion.
    This time, however, he checked his gasket and even applied some Vaseline (I think?) to it to be sure it sealed, but the pump is still putting air into his pool. He can't tell where air could be getting into the system anywhere else. He's had the pool forever, so it shouldn't be a 'noobie' mistake.
    Any ideas? thanks
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pump pumping air on start-up
    Pump drain plug O-rings? Water level in the skimmer or sticking skimmer weir? Clog in the skimmer piping? Anything new in the system?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    No vaseline on the gaskets, please.
    You should also check the pump inlet (male adapter threads) and any fittings on the suction side plumbing, especially unions and valve stems.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    paragraph 3 has a test that helped me out with a similar problem.
    pool-school/leak_detection
    Mar 2008
    Central VA
    328
    Thanks, that's exactly what he did...it's a bad valve on his skimmer line. He's handy enough to work with plumbing (unlike me), so he thinks he's got it licked.
    Todd
