Thread: Dewatering pool for three days on a well. Advice!!
    Jul 2016
    New Smyrna fl
    32
    Our pool needed debris dugout and backfilled with rock after hiting water. They have a pump hooked up into the rock with our hose running into the rock pumping out water. They are almost done rebar and pool isn't shot until Friday. They want the pump running until then with my well pump running the whole time. What should I do?
    If turned off they said it could cave the pool in. They dug 10ft backfilled with rock to 6.6
    Apr 2013
    Sacramento, CA
    2,769
    Re: Dewatering pool for three days on a well. Advice!!
    Follow instructions. It sounds like they are working to keep the area dewatered. It sounds like they are experienced. Can you post pictures
