Thread: Dead bird in skimmer- slam?
    Jul 2015
    PA
    17
    Was away yesterday for work, got home this evening and checked my chlorine per usual. Sitting at 6, happy times. Went to empty skimmer basket, and there is dead bird floating there. Removed said bird, but now I'm wondering if I should slam. And maybe change cartridges? I know birds can carry disease so that has me a little worried. Even with the 6ppm chlorine currently present. What would you guys and gals do?
    15x30 Above ground of unknown origin. Hayward cartridge filter w/2HP Pump. Aquabot Rover Robotic Cleaner. BBB and Relax.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Dead bird in skimmer- slam?
    Just raise FC 2-4 ppm and it will be fine.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Quote Originally Posted by pooldv View Post
    + 1
    If the dead bird didn't cause FC to drop...no worries. I.....on the other hand found a dead rat stuck to the wier door (dead) with his/her droppings below where they/it got stuck. I went to shock level for that. I think rats carry more diseases than birds.
    Maybe overkill.....no pun intended.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by AimeeH View Post
    + 1
    IMO it's mostly psychological- even at normal FC levels pathogens survive for less than a minute in the properly maintained pool. Great thing about algae is it tolerates higher chlorine concentration than pathogens so if you don't see it then nothing else lives there.
    According to some articles from this site fungus is surprisingly harder to kill than even algae. Luckily it needs a host to survive so if you don't have a kid with ring worm swimming in your pool you're fine from that side as well.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jul 2015
    PA
    17
    Thanks all for the reassurance, i raised chlorine 4ppm. Now I have some piece of mind.
