Results 1 to 16 of 16
Thread: Leak around pressure gauge
    May 2015
    TN
    312
    When I replaced the pressure gauge with the new one it is now leaking. So, now I have air in my lines and air is spewing off slowly affecting my prime of my pump. I used the tape around the threads. I also noticed that it looked like the previous gauge was screwed in too much and the nut portion at the top of the thread has "dug into" the hole some. Anyone have any ideas on how to fix the leak? I really don't want to have to buy the whole valve section and I have a pool party Saturday.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    30,403
    Re: Leak around pressure gauge
    The gauge is located on the pressure side of your system and has no bearing on whether your pump primes. What is causing your prime issues is an air leak on the suction side of your system....somewhere between the pump and the skimmer.
    It sounds like your pressure gauge is leaking, too, and that may be tough to fix....can you tell us if the damage to the threads is in the body receiving the gauge or do the threads on the gauge appear damaged?
    May 2015
    TN
    312
    Upon further inspection the threads inside the receiving body are stripped
    Is there a way to rig it up to work for a little while? Is it ok to let it run like it is?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Some Teflon tape might help for a bit.
    May 2015
    TN
    312
    Quote Originally Posted by pooldv View Post
    negative on the teflon tape. Already tried it
    DFW, TX
    24,450
    That only leaves duct tape or a new gauge. They have good ones at TFTestkits.net for like 13 bucks. It is fine to use it with a little leak.
    May 2015
    TN
    312
    Done bought a new gauge. The gauge isn't leaking. The threading inside the filter is stripped. So, now it leaks and I have air in my line.
    DFW, TX
    24,450
    Oh! Bummer. What about getting a bushing at Lowe's and tapping the next size up?
    May 2015
    TN
    312
    Even fine with it putting air in the line? I can hear air around the valve and in jets at steps.
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    48
    It sounds like you're dealing with two totally separate problems. Obviously a stripped thread on your valve head, which you may be able to repair. But the air in your lines should not be coming from that. Like Duraleigh said, your gauge is on the pressure side. It makes no sense that it's leaking (under pressure) and sucking air at the same time. I have no advice for the air in your lines but as another post offered, you can get a thread adapter/bushing for your gauge. You'll have to drill and tap your valve head for the larger threads of the bushing, then use teflon tape to install it...not too much force. Then simply screw your gauge into the bushing.
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    May 2015
    TN
    312
    Quote Originally Posted by 26venus View Post
    It has to be something to do with this. It wasn't doing it just before I attempted to change gauges..hmm
    26venus's Avatar
    Jul 2013
    48
    Okay, I can only go with what you're currently experiencing. It sounds like if you fix the gauge issue that the air leak should go away. You can try the repair route I described before. Not knowing how much of a DIY person you are I would describe this a 6 on a scale of 1-10 for difficulty. A lot of things could go wrong doing the repair...mess up the valve head when drilling for the bushing, tap the hole crooked or too deep, etc. Then there is the cost of the tools needed, assuming you don't already have them. I would guess $15 minimum. The other option, easier but more expensive is to replace the valve. They're like $90 on amazon and if you're a prime member it can get to you by Friday. You'll have a brand new valve and can still have the party Saturday.
    DFW, TX
    24,450
    Air in the lines after the pump is not a problem on its own. It won't hurt anything as long as your pump stays primed and everything works OK.
    But, as mentioned by others, it is strange. If the valve or gauge leaks then it should push water out when the pump is on. Unless it is creating some sort of venturi effect. Which is also strange. I assume your pressure gauge indictates a pressure reading above 0 psi when the pump is on. That is water pressure pushing against the gauge. I don't see how it could be sucking in air and give a pressure reading.
    May 2015
    TN
    312
    It is showing 10 psi at the moment. I checked the pump after it running all day and the air is gone. I forgot all about having to reprime the pump after I took the pressure gauge out. I opened the filter box before the pump and refilled it back up for good measure. I bet that is where my air came in. Evidentally, it just took a little while to get out of the system.
    DFW, TX
    24,450
    Yep, sounds good.
    May 2015
    TN
    312
    Yep, sounds good.
    It is still leaking, but not majorly. With our current rain, my pool is at the top of the skimmer. I could stand a small leak. haha
