Thread: Why variance between pool store computer and taylor 2006
    Aug 2015
    Georgia
    17
    I've been checking my pool more in last week than I ever did in 11 years of ownership. Been writing levels down to see any changes. I don't have a reagent for Salt level ( found out yesterday I can get one for that) so I went to store to see my salt level. Salt got very low on vacation and had to slam pool when we got home. My SWG doesn't have the a display w numbers, light with only good, add or low. I didn't tell them about my use of troublefree pool. They have a large computer type system they add the water to and results come up on screen, trending my pools results in my computer file, below are results
    K2006/computer
    pH 7.5/7.8 Mine was almost 7.6 but still had orange so called it 7.5
    FC 7.5/5.33
    CC .5/ Theirs says Chlorine total 5.3
    CH 325/194
    TA 70/53
    CYA 50/60
    Copper /0
    Iron /.2
    Salt 3140
    CSI -2.6/-4.1
    Their recomendation was to add 2 bags salt with each bag increasing level 250, said also needed to add some acid ( no amount given) to lower pH
    I'm managing my pool now with the poolmath but why such a difference in levels. I was happy with my levels and wasn't going to make any changes but their levels leave my CSI not where I want tem. I would have thought results would have been more similar. Am I just splitting hairs at this point and should I just leave it alone, lol I did get out of pool store with only buying salt though.
    16x32 Gunite, built 2005, approx 19,200
    Intellichlor IC40 SWG,1hp single stage pump, Sand filter,
    Taylor 2006 kit, well water filled
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Why variance between pool store computer and taylor 2006
    Trust your test results. We have seen thousands of times that pool store testing is not accurate. Only add salt if the SWG is giving a low salt error.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,532
    If you want to have "fun" take your water to 2 or 3 pool $tores...........I did it one time. Each store had different results needing different amounts of $$ to fix ranging from $50 to $175! The funny part is I had just tested my water and it was jewel like and spot on for TFP.
    The machines need to be calibrated often but are very rarely done so of course the results are off BUT it does cause $ells so.....it is good for them!
    The $tores that do it by hand do not rinse the tubes between tests and such things as that so...........that messes up the results again!
    Trust YOUR tests. NO one cares about your pool like you do.
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by RedDmax View Post
    K2006/computer
    FC 7.5/5.33
    CH 325/194
    TA 70/53
    CYA 50/60
    Copper /0
    Iron /.2
    Salt 3140
    CSI -2.6/-4.1
    Your CSI - I think you mean -.26 & -.41
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    May 2016
    Phoenix AZ
    128
    Quote Originally Posted by kimkats View Post
    +1
    The only time you should get the pool store to test your water is if you suspect metals in it and, even then, it's just an indication, not a good measurement.
    They are just in too much of a hurry and too careless with cross-contamination and lighting to get consistent, accurate results.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    They have a large computer type system they add the water to and results come up on screen... I'm managing my pool now with the poolmath but why such a difference in levels.
    Easy- the K2006 is there to tell you the level of chemicals in your water. The pool store's computer is there to make you buy stuff from them.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
