Results 1 to 7 of 7
Thread: Outdoor kitchen countertop choice, granite vs. concrete
    Aug 2016
    Bakersfield, CA
    1
    Does anyone have experience or can recommend if solid slab granite is any better than poured concrete?
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,511
    Re: Outdoor kitchen countertop choice, granite vs. concrete
    No experience with concrete but have granite. In retrospect I should have used quartz. Granite is a pain as it soaks up oils. I have tried to seal it but does not seem to last long out in the elements.
    Good Luck.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have black tile and man does it get hot in the sun. Keep the heat factor in the equation if it is exposed to the sun.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Our neighbor has Quartz..... highly recommend
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Jun 2015
    Orange County, CA
    145
    I have granite in a covered outdoor kitchen. It's fine and works well and cost was the only reason I didn't go with Quartz over granite. My neighbor has concrete and it's fine also. Really personal preference and cost choices. All things being equal (which of course they're not), I would choose Quartz over granite and concrete every day of the week.
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    Feb 2015
    Santa Cruz, CA
    367
    We went with concrete, in a light gray finish to keep it cooler in the direct sun. Darker concrete and granite can get pretty hot. We used 1ft square granite tiles for a BBQ island at our last home and they worked pretty well.
    We have looked at also prefabricated quartz, but it wasn't rated for outdoor use - the outdoor versions were too pricey for us.
    2015 Build Link: 15'x30' Rectangle (3'-6", 5', 4' depth) 14,000 Gallon Pool, Finish: Wet Edge Primera Stone Black Kona. TF-100 Test Kit, Dolphin DX5+S Robot, Jandy CL460 Filter, VS 2HP pump, AquaPure 1400 SWG, iAqualink2, Automatic Safety Cover. No Heater
    Jun 2011
    Carlsbad, NM
    172
    I have sealed dark emperador marble and it is holding up well after 2 years.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
