Results 1 to 9 of 9
Thread: Gunite in ground paint fade
    Jul 2015
    Knoxville
    72
    Has anybody here attempted a new diy paint job for their pool, any reviews for the material, installation and tips like when to do it (before or after the pool season). How much time can u leave a pool empty to recoat it without it popping outta the ground? That last one scares the heck outta me lol
    26k (roughly, irregular shape) 10' at deepest diving board and waterslide, IG gunite, 1hp Hayward super pump, 3/4 hp pusher for Polaris280, Hayward s244t sand filter, auto tablet chlorinator, clueless owner.... Knoxville tn, #tf-100 owner#
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Gunite in ground paint fade
    Most gunite pools are plastered, not painted. Did the pool once have plaster? Paint will usually only last a few years.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    There are a few diy paint and even a couple of diy replaster jobs in the archives. Painting really isn't worth the effort since it only lasts 2-3 years. Better off to live with it for a while and save up for a replaster.
    Apr 2013
    Sacramento, CA
    2,769
    Some pools can be left empty for years without a problem. Some pools pop the day after they are drained. It depends on soil type and groundwater. Doe the pool have a hydrostatic relief valve?
    Regardless of the manufacturers warranty claims pool paint generally only lasts a couple of years.
    Jul 2015
    Knoxville
    72
    Not sure if it has a hydrostatic relief valve i just purchased the house last year with the pool already in place ... how can I check this out
    Jul 2015
    Knoxville
    72
    Not sure but it looks like it has been painted probably quite some time ago, this pool is by no means a new pool,the previous owners purchased the home 15 years ago with the pool also
    Jul 2015
    Knoxville
    72
    Replaster sounds expensive ugh lol
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    If you can remove the main drain cover, the hydrostatic valve is normally under it.
    I had a painted pool as well...waste of time and resources...better off to do nothing if you can't re-plaster.
    Dolphin E10 Cleaning Robot.
    Nov 2011
    Moberly,MO
    1,010
    ecoFinish is also an option rather than paint or plaster
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
