Thread: Clarifier
    May 2009
    Berwick Pennslyvania
    15
    Clarifier
    I've finally turned the corner on a pool that was off the charts chemically. All of my readings are in range, algae is under control, but my water is still cloudy. Would it be wise at this point to add some clarifier? What does clarifier do if anything to other chemicals?
    20K gal.
    Hayward S-244T sand filter
    IG vinyl
    Re: Clarifier
    It is very unusual to need to use clarifier, normally the filter will clear the water if you give it enough time. I only recommend clarifier if the filter appears to be working correctly, FC levels are behaving normally, and you have had mild cloudiness for several days without any visible change for better or worse. Normally it is better to save your money and let the filter do it's job.
    Clarifier has no real effect on any of your chemical levels.
    Feb 2008
    Denton, TX
    5,061
    Re: Clarifier
    Clarifier is an option, but it is usually not needed excepting a few rare circumstances. Generally all that is needed are balanced numbers and filter time assuming that everything mechanical is working as designed.
    Go ahead and post a full set of numbers just so we can be sure that no stone is left unturned.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Clarifier
    Is your FC holding overnight?
    Have you tried a little DE in the filter?
    May 2009
    15
    Re: Clarifier
    Don't have the exact numbers in front of me at this time. I haven't tried DE in the filter. Think I will just give it some time. Thanks for the help.
    20K gal.
    IG vinyl
