Thread: How to Determine When to Re-Plaster?
    Dec 2009
    San Antonio, Texas
    78
    How do you know when you need to re-plaster?
    I twisted the arms of Gary Pools here in San Antonio and, while they wanted to send someone out, they did tell me that plastering starts at $5,000 and goes up. Is this true?
    (The pool is perhaps 10 years old, and we have been maintaining a good chemical balance for the last six years, but I have no indication that it was maintained well prior to that.)
    ETA: If we need it at all it's likely because of one 4 square inch part that looks bare.
    Jaywalker
    In-ground, 11,000 gallon, plaster, in-line trichlor pucks or BBB bottled chlorine, 1.5 HP pump @ ~100 gallons/minute, cartridge filter
    Jul 2015
    Central Valley CA
    1,107
    Re: How to Determine When to Re-Plaster?
    Plaster is a lot like paint on a car most of the time it is an aesthetic issue that causes people to do a re-plaster that or texture. You only NEED a re-plaster if you are loosing water but if you have bare spots, are scuffing toes because the texture or just generally looks bad then you are probably at the point it is time to start thinking about it. As for price, with anything major relating to pool best to get a few quotes. For plaster I wold be more concerned with reputation and quality than price a $1000 difference for a well respected company who knows what they are doing is a small price to pay for something you will have to look at for years to come.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Dec 2009
    San Antonio, Texas
    78
    Thanks. I don't know if I'm losing water, and I'm not sure about "scuffing toes;" that one spot looks bad but it's petty limited. I appreciate it.
    Jaywalker
