Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: HEELLLPPPP!!!! Pool Filter/Pump Assembly problems
    Jul 2016
    Chardon
    32
    I have had nothing but issues with the install of this pool. First it was many leaks, I got those handled. Now I am having issues with the filter/pump assembly setup. The pool still plagues me. So last night I ran the electric for the pump. I hooked all hoses up to the pump, filter/frog system, skimmer, and return according the instructions. it said to open the air relief valve on top of the filter, i did that. It said to turn the pump on low and allow the air to purge from the system and once it started spraying water out of the air relief to close it. I did that too. The problem is water is still coming out of the air relief, and there is water coming from the band clamp that holds the two filter halves together. The pressure gauge reads 0. I am just not having good luck with this pool. This pump/filter was bought new so this is the first time its been used. Do I need to replace gaskets/o-rings? I am at a loss. Its a new system and I am having nothing but issues. I cant help but feel that I am screwing things up and I am more than ready to just toss in the towel. The filter is a Backyard Auqa Design D.E. filter system which is a Waterway system.
    27' x 54" Vogue Panache Pool 18k Gallons | Above Ground Aluminum Wall/Resin Tops and Posts | 1HP/2 speed pump | Waterway DE Filtration system
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Re: HEELLLPPPP!!!! Pool Filter/Pump Assembly problems
    Share a picture of your set up.
    Did you put any lube on the o-rings? This is one thing you can get from the pool store but some Lowes have it. Here are some examples:
    Amazon.com: pool lube tube
    One thing you can do is take it all apart and start over one piece at a time. Go slow. lube when you see an o-ring.
    Jul 2016
    Chardon
    32
    Kimkats,
    Here are the pictures of the setup. I had to take the hose off the frog system because the water just kept flowing back into the filter and puking out all its openings.
    Jul 2012
    Tallahassee, FL
    30,638
    Simple set up so should be easy to work through. Going to go item by item:
    -frog system-please do some reading. It is not a good system It adds metal to your water that can cause staining of the liner and hair
    Do a search up in the search box at the top of the page to help you understand the whys and whats.
    -Valves-you really need two shut off valves. One right under the skimmer and one right at the return. It will make your pool life MUCH easier.
    -under skimmer and return-think about digging down a little and putting rocks for drainage there. THEN put another set of pavers there. Your pool WILL overflow at one time or another. You do NOT want it to flush the dirt from under your pool after all of your hard work to level it and set it up. I angled my pavers just enough for the water to flow away from the pool.
    -hard plumbing ONCE you get the equipment fixed up and holding water. We can help with that when you are ready.
    -o-ring lube! I am VERY hopeful THAT will fix your water coming out of those areas. ONLY use pool lube as the other products will damage your rubber and you will be worse off than now.
    -places to put lube-
    1.o-ring on the air relief valve
    2. o-ring that is between the two halves of the filter body,
    3. o-ring in side the top of the filter basket lid
    4. ? not sure if you will have this but there might be an o-right in the union from the pump to the filter.
    OH and unions!! You will need unions to let you disconnect everything when you hard plumb it later.
    So go shopping for the lube and see how that helps with the water going every where.
    Please think about the frog stuff.
    I use just plain chlorine/bleach and have a pool that looks like a jewel. Beware the tablets and powder chlorine products as they add stuff to the water like CYA (stabilizer) that will build up over time and cause major problems down the road.
    Jul 2016
    Chardon
    32
    Kimkats,
    I had already planned on getting rid of the frog system, due to a friend of ours that turned us onto this site. They use just bleach in their pool. I wanted to go to that. I was just going to use what came with it, but after you tell me this I think I may just get rid of it now and go down the right road to begin with. I will get some pool lube after work and start lubing the o-rings. As to #4 there wasn't an oring in the union from the pump to the filter, but it did have a 2" gasket. Should I just lube that up also?
    Jul 2012
    Tallahassee, FL
    30,638
    It cannot hurt! Lets do it all!
    Jul 2016
    Chardon
    32
    Ok I'm gonna get after it right after work. I am gonna need direction as to how to go about my water with out the frog.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    You should be able to unscrew the pipe from filter to the frog. take the other fitting off the frog and screw it in the filter. then the hose to return eyeball fitting.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2012
    Tallahassee, FL
    30,638
    Quote Originally Posted by Andyb2241 View Post
    Sent from my SM-G930V using Tapatalk
    This is where the valves under the skimmer and return will be helpful.........but until you get those you can put a tennis ball in the skimmer and a chiseled potato in the return UNLESS you can find a return plug. We want to stop the water from coming out of the pool all over the place. You might have better luck than I in getting the hoses to stay in the pool while I work on the equipment but then you will still have a water going every where when you try to hook them back up to the equipment.
    okay after froggy............I can't really see how it connects to the filter but it looks like it is just a hard connector? Do you think you could just take the frog off and put the hose in place of the frog?
    Another idea would be to take the frog guts for right now until you set it all up with hard plumbing.
    Quote Originally Posted by banditig View Post
    Well look at that! Best idea of all! THANKS! Of course that is after you figure out how to keep the water IN the pool LOL
    Jul 2016
    Chardon
    32
    Yep yep. I was talking more as to how to treat the water.
    Jul 2016
    Chardon
    32
    The frog is a goner! I will be removing it tonight. I wish I would have done more research before. The pool salesguy was very convincing that we needed this thing. That it would keep less chemicals in our pool making it safer. Bunch of malarkey!
    Jul 2012
    Tallahassee, FL
    30,638
    OH how to keep your water?? Well I have those answers also!
    So do you have or have you ordered your test kit yet? Look in my siggy for the one I think it is the best buy as it has more of the regents we use on a daily bases.
    AND here is a set of links I put together for new pool owners! It is a LOT of info so take it slow. It will all start to make sense when you get your test kit and start using it.
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    these valves would be easy for your setup
    https://www.amazon.com/Inch-Swimming...ol+gate+valves
    But if your going to hard plumb the jandy valves are best
    Jul 2016
    Chardon
    32
    kimkats,
    I just have the test strips that came with the pool. I will take your suggestion about the TF-100 Test Kit. Do you feel the Speedstir Magnetic Stirrer is something I should have from the beginning or should I just get the kit for now? I will start reading those pages. Thank you very much for your guidance and direction.
    Jul 2012
    Tallahassee, FL
    30,638
    I have asked Santa for the magnetic stirrer. I hope I get it as EVERYone that has one LOVES it!
    LOL we call the test strips guess strips for a reason.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Quote Originally Posted by kimkats View Post
    Pavers, check. My real goal for overflow coming out the skimmer is going to come after I plumb a line for backflushing. I'm going to run a small hose from the wall of the skimmer to that line. It won't help when the kids are splashing, but when it rains for a week I won't have a problem.
    ... you can put a tennis ball in the skimmer...
    Wow. That's the best thing I've read so far this week. Now I'm just embarrassed about how I block off the skimmer when I'm working on something.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Jul 2016
    Chardon
    32
    Well since the boss (a.k.a. my wife) is the one that wanted the pool the most. I think if I ask for the magnetic stirrer she will be happy to oblige when I tell her that it will keep the water nice and clear!
    Jul 2012
    Tallahassee, FL
    30,638
    ahhhhhhh but NOW is the time to have at least the pavers down. Those hoses pop off SO easy then you have a mess on your hands. Ask me how I know Had a wash out due to the hose popping off the first night the pool was filled. I had to push the sand back in as best I could. NOT fun and tore my hands up from the abrasions from the sand. That area is bumpy and not as nice as the rest of the pool.
    I like the potato trick myself.........."honey can you pic a large potato up for the pool on the way how?" LOL
    Jul 2016
    Chardon
    32
    I must admit after all the stuff this pool has put me through. Last night's fiasco had me convinced I was done with this thing. Just completely frustrated. Talking with ya'll I am feeling a little excited about being a pool owner.
  20. Back To Top    #20
    Eustis, Florida
    68
    It looks like a great pool, this is just a stumbling block along the way. You'll be loving it once you get it up and running!
    AGP 33' x 54" Lomart Verona, Approx. 27,300 gallons, Pentair cartridge filter/pump 2-speed, 1.5 hp, Dolphin Escape robotic cleaner.
