Results 1 to 13 of 13
Thread: Can't get those tiny dust particles out! Any ideas?
    Jul 2016
    Barcelona, Spain
    14
    I always have a bunch of tiny dust particles on the bottom of my pool. I use floculant (maybe not enough, not sure) and while my Dolphin is working i leave the pump on.
    I get the feeling that the Dolphin is just throwing the dust around because when it's cleaning the pool looks great but after an hour or so the bottom is full of particles again.
    I hope you can see them on the photos.
    Any ideas?
    Ton.
    25m3, in-ground, home-built (or apparently some french company that didn't know what they were doing), vinyl liner
    Speck Badu 42/9 pump, Zodiac Boreal sand filter, Dolphin Zenit 10 robot
    pH 7.0-7.2, Cl 0.3-0.6mg/l
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Can't get those tiny dust particles out! Any ideas?
    Im currently in the same situation... could be dust, could be dead algae... Either way, Im contemplating doing the DE add to my filter because as soon as I vacuum it up I just get more.
    The dolphin may just be stirring it up when it passes by...
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    tucsontico's Avatar
    Mar 2014
    202
    What model of Dolphin Robotic cleaner do you have? Some of the newer models have ultra-fine filters and can vacuum dust particles pretty well. My Nautilus Plus has such filters and I'm always amazed by the amount of fine dust-like particles it picks up. I suggest you carefully check your robot to see if anything is clogged or damaged.
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    Jul 2016
    Barcelona, Spain
    14
    Quote Originally Posted by tucsontico View Post
    Dolphin Zenit 10 (sig updated).
    What would i be looking for? I regularly change the filters and all seems to be ok. Maybe the valves in the bottom of the filter compartment? What i never clean actually is the fan on the top. I don't see the need for that.
    Does fluculant help in this case? Or am i understanding things wrongly?
    Ton.
    30,432
    well, if it's dead algae (and I think it is), that means you have live algae in your pool and no amount of filtering will get rid of it.
    Chlorine will keep re-occurring "dust""dirt""pollen" out of your pool because it kills the live algae (which is what it usually is) that is the cause of the recurrence.
    Elevate your chlorine to twice normal and hold it there for a couple of days. That usually clears it up.
    Mar 2013
    Missouri
    40
    I was just curious when you say 'twice normal' level for chlorine, does that mean twice the minimum for his CYA level? or twice the level that he normally doses to with his daily chlorine dosage up to his shock/slam level for his CYA. Sorry if this obvious, but I just wasn't sure what you meant by 'twice normal".
    cruiser310
    25,000 gallon, 33'x54" Round AG Sharkline Matrix, 26" sand filter, 2 speed, 1 hp Pentair optiflo pump
    tucsontico's Avatar
    Mar 2014
    202
    Quote Originally Posted by Toontje View Post
    Ton.
    A Zenit 10 appears to be a euro version of the Nautilus plus. Definitely check the impeller for debris. The owners manual has a good picture showing how to do that:http://manuals.maytronics.com/images...ler_cover1.jpg. Additionally, be certain you are using the fine porosity filters. There are two types that came with your Dolphin and the finest mesh are the ones you want to use for your situation.
    Flocculant should help "gather" smaller particles into larger ones for easier filtration. However, I agree with duraleigh, what you're seeing may be dead algae and you need to elevate your chlorine level for a few days.
    Jul 2016
    Barcelona, Spain
    14
    Chlorine on high level, but still the dust in the pool. I don't seem to get rid of it. Maybe try a manual vacuum cleaner?
    Dec 2014
    Santa Ana, CA
    523
    can you vacuum this to waste manually after it settles at the bottom next time?
    this forum promotes slightly different approach to pool care which is more scientific if you wish. It starts from getting good test kit to know your exact chem levels and it uses very simple chemical system which consists of liquid chlorine as sanitizer and simple pH adjusters. No flocculants or other chems are ever needed in the common cases. Since you're from Spain nobody asked yet about your test results but in general we prefer hard numbers like FC = 5 ppm and not low/high/etc as that all relative.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jul 2016
    Barcelona, Spain
    14
    Quote Originally Posted by max2k View Post
    How's that then? When you're from Spain nobody is interested in the test results? Or is the situation for Spain different? What's up with that?
    BTW, the levels i try to maintain are in my sig now. Please let me know if i need to go up or down with those.
    Dec 2014
    Santa Ana, CA
    523
    Is TF-100 test kit available there? That's what we use around here and it makes things easier as we know it has proven accuracy / repeatability so we can compare one pool to another.
    When you say CL = 0.3-0.6 mg/L which is the same as 0.3 - 0.6 ppm we can't really compare it to what we usually see as we have no idea how that was measured. We also don't know what other chemicals you might use to keep algae at bay- your chlorine level looks unusually low.
    IIRC FC = 2 ppm will drop to 0 in outdoors pool in about 2 hours due to the Sun UV radiation if you don't have any stabilizer in there. From that point of view your pool has 0 chlorine almost all the time or you have some other way to keep it sanitized.
    As you probably see we have reasons to ask new members to purchase TF-100 kit and post the following test results so some more specific recommendations could be made:
    FC=
    CC=
    CYA=
    pH=
    TA=
    Jul 2016
    Barcelona, Spain
    14
    Don't know. Have to look around. So far i haven't seen them in shops. Maybe online.
    Only Clorine tablets (which probably have a lot of other stuff in them as well) and "pH increase", that's what it's called here.
    Got the message. Will look around.
    Dec 2014
    Santa Ana, CA
    523
    The kit, not sure if it can be shipped to Spain
    another recognized one is K2006 from Taylor, I believe both are available on Amazon too.
