Thread: Leak adjustment
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    Leak adjustment
    I'm taking care of a neighbor's pool who has moved 1000 miles away and is renting the property. The house is in a future highway right of way so he can't sell it and doesn't want to spend any more than necessary for repairs. Its an ig fg, around 4-5k gallons. I turned the tenants on to TFP as soon as they moved in, did a full set up and chemistry adjustment prior. Apparently there is a leak, I haven't had a chance to check the hydrostatic valve (I will when I can get my scuba gear back from a remote location.) In the meantime I have recommended that he utilize the puck chlorinator and I'll check the CYA and other levels periodically. The pool is losing too much water for evaporation to account for the drop. Make up water is from a softener, so that is a help. Other than adding bleach and MA to supplement the pucks, are there any other suggestions?
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Jun 2014
    15,153
    Re: Leak adjustment
    Perhaps keep an eye on CYA more than normal as in time that should drop as well.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: Leak adjustment
    If they are using pucks the MA might not be needed as pucks tend to make PH drop.
    You are doing all you can. They really need their own kit to keep on top of it though (as I am sure you know but needed to say it).
    Feb 2009
    357
    Re: Leak adjustment
    I suggested that they get their own kit (and he knew that) since I can't always get there. Losing both CYA and CL is the concern. Plus they have small kids that like to splash a LOT, so splash out is another issue. Ironically, pool stores offer potions that claim to reduce pool maintenance but don't while the TFP method while initially a bit more effort DOES reduce maintenance significantly!
