Thread: NEW Intex 10 * 30 Metal Frame Pool Help Please
    Just setup pool yesterday total noob here I setup right on my driveway is leveled
    questions for yall
    is there anything I can put underneath padding or something floor is very roof
    what filter and pump should I get since I read that one that comes with it will not do a good job in review of pool
    how long and when should I run my filter
    what kit and chemicals should I get
    is the saltwater intex cleaner worth buying for size of my pool
    thx for your help in advance
    BTW I am in North East
    INTEX ULTRA FRAME RECTANGULAR POOL SET, 32' x 16' x 52", Water Capacity (90%): 14,364 Gallons
    Intex Easy Set 4000 gph Filter Pump, 110~120 Volts - 3/4 HP , Hayward c751 star clear filter.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: NEW Intex 10 * 30 Metal Frame Pool Help Please
    Welcome to the forum.
    I'm confused is your pool round oval, or rectangle? Is there water in it yet?
    Driveway huh? Yes, you should probably invest in some kind of floor padding, like this - note I'm not endorsing this online site, just giving you an idea of the product I'm talking about. I have no experience with it, just seen it mentioned on this site.
    Yes, the Intex SWG gets decent reviews - if you can swing it for your pool I would.
    The pump/filters get bad reviews because many times the pool owners get algae and the filters are not good for clearing them. If you prevent the algae from happening, you may do okay with it. If you do want to upgrade, there are a couple articles in Pool School to read that may help you make a choice, and others who have upgraded will probably chime in to give their reviews.
    Do a google search (bottom Left corner) of Intex pools topics on this forum and there will be lots of good info contained there to help you.
    Run time: With the intex filter/pumps, I would run them during the day, for at least 8 hours. You want to run the pump anytime you have swimmers, and also anytime you are adding chemicals and also for a couple hours after any chemical addition.
    The best thing to do right now is order a TF100 test kit online, or a Taylor K-2006. This way with proper testing and chem additions, you can prevent problems from happening in the first place.
    11,969
    Hey, just saw a post that recommends foam board or something, read this thread....
    http://www.troublefreepool.com/armor...nd-t12449.html
    I used floor padding from homedepot for hardwood floor worked like a charm very happy with ut
