Thread: cc testing
    Dec 2015
    Newington, Connecticut
    113
    cc testing
    Using the tf 100 test kit how long do you wait after adding drops to test cc levels to read the pink color. When I first add the drops the water stays clear. A couple minutes later the water turns slightly pink equal to .5 ppm. Never higher.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Jul 2015
    Central Valley CA
    1,109
    Re: cc testing
    If it is clear directly after the 5th drop assuming you are swirling or have speed stir then you don't have any CC. It will turn slightly pink after a bit of time as you have discovered that is normal and not an indication of CC
    The FC test will do the same, turn from clear at the end of the test to slight pink if allowed to sit for a min or two
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Re: cc testing
    Hi Andrew,
    you need to test for CC immediately after completing the FC test.
    If you wait until the water turns pink again, you waited too long.
    Divin Dave,
    Dec 2015
    113
    Re: cc testing
    Thank you
