Thread: Is this a leak?
    Is this a leak?
    I was digging next to where the pipes run between the pool and the equipment pad and found wet dirt down at pipe level - about 24" below grade. At first I thought I must have cracked one of the PVC pipes while digging but now I'm not sure. I dug a trench to expose about 3 feet of the pipes so I could find the leak and have enough room to do a repair, but I can't find any crack or damage in any of the pipes.
    Here's what is happening: There is about 1" of water in the bottom of the trench, just enough to cover the pipes. When I suck this water out with a Shop Vac, the bottom inch will refill in less than 5 minutes but the trench does not fill any more than that bottom inch. The pool is about 15' away and the water level in the trench is about 18" below the level in the pool, so the head in the pool doesn't seem to be operating on the water in the trench. Running the pump and switching the valves between pool and spa, and running the booster pump for the cleaner, doesn't change anything. If I run the pump and then Shop Vac the water out of the trench, the bottom of the trench will refill with an inch of water in about 5 minutes even while the pump is running.
    I'm thinking that if a return line was cracked, then the trench would fill with water while the pump was running. If a suction line was cracked, then the water in the bottom of the trench would get sucked into the suction line. Because running the pump doesn't change what is happening with the water in the trench, I'm thinking that the water must not be coming from any of the pool lines. Am I correct in thinking that a crack in either a suction or return line would cause the water in the trench to go down or up when the pump was running? Please offer suggestions because I can't figure this one out. We don't have high groundwater in my area, so that can't be the source.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Is this a leak?
    Test the water in the trench for chlorine to determine if it's pool water.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Is this a leak?
    You've got the right idea, with the system running the water in the trench should change if it's a plumbing leak
    How much rain have you had lately, this could just be a surface water issue that you can see in the trench 8) (I like John's test too ) Are you loosing any water from the pool?
    (almost forgot ) Welcome to TFP!!
    Luv& Luk
    -Ted
    Re: Is this a leak?
    The water was gone today, so nothing left to test. We haven't had rain for a while but it must have been from landscape watering. I'm just glad it wasn't pool related. Thanks for the suggestions.
    Mar 2007
    4,160
    Re: Is this a leak?
    Just to be sure, you can make a pencil mark on the skimmer at the waterline and check it tomorrow see if the water dropped over the course of a day (~3/ 16" can be attributed to evaporation (depending on air and water temps))
    Luv& Luk
    -Ted
