Results 1 to 7 of 7
Thread: White residue on stone
    Mar 2014
    McKinney, TX
    12
    What is this and how should I clean it. In case it doesn't come through in the pics, it's a white residue that appears to be leaking from our rocks/stone onto the tile. It's on the side of the hot tub as well as stones under the waterfall. (No picture of waterfall) I've tried scrubbing with various things. It's like a glue or cement. It's very hard.
    [/URL]
    31K gal, IG pool & Spa, Tropics Blue pebble, Jandy 2.0 VarSpd, Jandy 60 SqFt DE Filter, AquaPure Salt System, Jandy LRZ400 Htr, Polaris 280 cleaning sys, Jandy PDA PS6 Computer, Estimated completion 7/25/14
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: White residue on stone
    It is either efflorescence pushing through the mortar or it is scale.
    Muriatic acid will take it off.
    Your water is very likely to scale and you need to manage your CSI. Enter all your results into PoolMath and it will give you a CSI score. Keep that number -0.3 to 0 to prevent scale. Adjust pH and TA to change the CSI. More here, Pool School - Calcium Scaling
    Mar 2014
    McKinney, TX
    12
    Thanks. How should I clean it with Muriatic acid? Dilute (what ratio) and apply with a brush?
    DFW, TX
    24,485
    You can try diluting it 1 to 1 with water but stone guys usually use it straight. In a spray bottle is probably best and then brush it.
    Aug 2015
    Plano, TX
    217
    Wear gloves! That stuff is dangerous. When I got my pool it had calcium spots like that. I mixed it 50/50 and put it in a pesticide spray can made for chemicals, the kind you pump up and it sprays a fine mist. Spray, let it foam, hit it with the water hose. Repeat. Many times. It'll disappear in a few minutes.
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    That stuff is annoying and recurring. I've used razor blade scraper on the tiles. Probably should try the spray acid/scrub for the rock. Balance!
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Oct 2015
    Keller/Texas
    16
    Muratic acid
    In-ground; 34,000 gal; Pentair Equipment; Hot tub; Bench Entry; Weeping Wall; Happy Family
