Thread: TA drop with CH rise?
    May 2016
    Central Valley/ CA
    28
    On 07/09 I got the following results after testing:
    FC 17.5 (FC was high to deal with the lack of a working pump)
    TC 0
    TA 110
    CH 290
    CYA 80
    PH 7.5
    Tested today:
    FC 7.0
    TC 0
    TA 90
    CH 330
    CYA 80
    PH 7.8
    Should I be concerned about the rise in CH and fall of the TA? I haven't added any chemicals besides MA and Chlorine to deal with PH and FC levels. Are these levels ok or is there something that needs to be done??
    35,049 gal in ground free form pool, Jandy CL580 Cartridge filter, Jandy SHPF2.0-0 pump, Chlorine
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: TA drop with CH rise?
    No. The TA falling is good. You want it in the 50-60 range.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Your FC and TC numbers should be close or equal. Are you referring to CC and not TC?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    May 2016
    Central Valley/ CA
    28
    Correct.
    May 2016
    Central Valley/ CA
    28
    So the CH is nothing to worry about?
    DFW, TX
    24,497
    No, your CH is fine. Why are you worried about it?
