Thread: Does the auto fill maintain water level in just the pool??
    May 2015
    Fullerton, CA
    636
    I have a auto fill that puts water into the pool when low. Do I need to manually add water to the spa? I have a raised spa that's connected to the same pump, I am not using the spa bi-pass, I have the spillover set for 1 hour per day, the suction is from the pool and only the spa returns are on during this schedule. I guess without an auto fill on the spa I will have to manually fill it.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Does the auto fill maintain water level in just the pool??
    The spillover is taking water from the pool and filling (actually overfilling) the spa, so your auto fill will keep both the pool and spa filled.
    chiefwej
    May 2015
    Fullerton, CA
    636
    Thank you.
