Thread: Vaccuum problem
    Vaccuum problem
    I have a Hayward Sand Filter on a 20 by 40, 27K gallon pool. After returning from vacation we had a Algae outbreak that is mostly contained now, however, when vaccuuming the dead algae up from the bottom, it appears the dirty water is coming right back into the pool through the jets. I've replaced the sand, the Multiport and spider gasket in an effort to solve it with no luck as of yet. Any ideas, suggestions? Thanks in advance.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Vaccuum problem
    HI
    You could vacuum to waste or also could try adding some DE to your sand filter. Pool School - Add DE to a Sand Filter
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,403
    Re: Vaccuum problem
    I assume you backwash when you see the dirty water coming out, right?
    Do you rinse?
