Thread: sequestrant, should I add it?
    May 2015
    Fullerton, CA
    636
    read something about adding this or is it mainly for well water? Will it help anything?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Jul 2015
    Central Valley CA
    1,109
    Re: sequestrant, should I add it?
    Usually added once by PB for new pools or re-plaster after that not needed unless you have a metal problem with fill water.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Sequestrant is to bind metals in the water so they don't fall out of solution and discolor the pool or the water after chlorine is added, and it can help some with preventing calcium scale when high calcium levels are present. If you don't have either of those situations then there is no need for it.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    Fullerton, CA
    636
    It's a 6 day old fill. My CH was 325, city water. Chlorine is in the pool, I did not add for 48 hours per NPT stonescape recs.
    30,432
    If your fill is city water, the chances are slim that you have any form of metal in your water. As a result, you do not need sequestrant.
