Results 1 to 10 of 10
Thread: pool suction
    Aug 2016
    chandler az
    11
    pool suction
    hi, hoping someone can help me. I just recently changed my DE filter to a cartridge filer. I'm getting very little suction when I connect my Zodiac cleaner. the filter reads 10 psi. When I connect my line to the skimmer the filter reads 0, but I get a lot of suction and able to clean the bottom of the pool. What is my problem?
    thank you
    30,421
    Re: pool suction
    Welcome to the forum.
    Too confusing. You've got some variables there I can't quite understand.
    Pump running, is there only water in the pump strainer basket or air bubbles, too. How about pump running and zodiac hooked up....just water or water and air bubbles in the pump strainer basket?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: pool suction
    Welcome to TFP!
    Please add your pool info to your signature as shown here, Pool School - Read This BEFORE You Post
    Aug 2016
    chandler az
    11
    Re: pool suction
    thank you.
    the pump is running and there is water in the pump strainer, no bubbles. The pump is running when I have the zodiac hooked up, but it doesn't move and get very little suction. The reading at the filter is 10 psi, and getting a lot of suction of the skimmer. I then try to connect the zodiac to the skimmer and then get a reading of 0 psi but a lot of suction. I just replaced the diagram on the zodiac and it still wont move.
    does this help? thanks in advance
    chlorine pool
    15,500 gallons
    in-ground
    Pentair cartridge filter
    1 hp motor
    Jul 2007
    Hillsborough, NC
    525
    Re: poor suction at vacum
    What's the difference between connecting your Zodiac cleaner and connecting your 'line'? What do you mean by line? Do you mean just the hose itself without the cleaner attached to it? If so, that suggests the Zodiac is the issue.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Aug 2016
    chandler az
    11
    thanks for your reply. by line I mean the zodiac cleaner hose. I just replaced the diaphragm on the zodiac.
    What would cause the skimmer line to drop to Zero when I connect the hose to it?
    chlorine pool
    15,500 gallons
    in-ground
    1 hp motor
    Jul 2007
    Hillsborough, NC
    525
    Quote Originally Posted by louman007 View Post
    that's what your original post said. I'm a bit confused as to the problem you're trying to solve. Are you trying to solve the problem of when you connect the zodiac to the pool you have no suction but if you connect the line by itself you have suction? are you trying to solve the problem of when you connect the zodiac to the pool pressure drops to 0 but you still have suction?
    When the zodiac is attached are you vacuuming to waste or is the water returning to the pool?
    Aug 2016
    chandler az
    11
    what I'm trying to say is that I get little suction on the vacuum inlet (outlet?) where I would normally connect a vacuum. When I connect the vacuum to the skimmer inlet (outlet?) I get great suction but the filter psi goes from 10 psi to 1 psi. Is that normal?
    chlorine pool
    15,500 gallons
    in-ground
    1 hp motor
    Jul 2007
    Hillsborough, NC
    525
    Re: pool suction
    Are you vacuuming to waste? when I vac to waste, my pressure gauge reads 0. My pool doesn't have a separate inlet for a pool vacuum. Yours does. Do you have to put the filter in a vacuum mode to use it, or is there a valve on it?
    Aug 2016
    chandler az
    11
    Re: pool suction
    i don't have waste connection. i don't know if the filter has a vacuum mode. how do i find that out? there is a valve but nothing changes if i move it.
    chlorine pool
    15,500 gallons
    in-ground
    1 hp motor
