Results 1 to 10 of 10
Thread: question about pucks and liquid chlorine
    Can I use them both at the same time? I use plain bleach most of the time. But if I'm gone all day or longer I want a way to make sure my chlorine dosen't get too low. So on the days I wont be there to ad liquid chlorine, is it ok to put a puck in the skimmer basket? My cya is about 40. about how long doing this would it take to raise cya too high? Thankyou. Filix.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: question about pucks and liquid chlorine
    As long as you know how much CYA you are adding it's fine. There is a section at the bottom of Pool Math, "Effect of Adding Chemicals". You should be able to go longer than a day without testing and adding if you know your pool's appetite though.
    NEVER (!!!!) put pucks in a skimmer basket! They are very acidic and can cause damage. Either use a puck floater or put them in a sock and hang them in front of a return.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    You can check at the bottom of the PoolMath page for the amount of CYA added by each puck. A lot of people will use them for extended time away, like a vacation. But getting into the habit of doing it daily will get your CYA out of hand pretty quickly. Just raise your target for you chlorine additions daily. With CYA of 40, you should be targeting FC of 5 with a minimum of 3. So shoot for 6 or 7 if you think you will drop below 3. Then you have the room to add pucks if you go on vacation and not worry about your CYA getting out of hand.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jul 2015
    Central Valley CA
    1,107
    You can use them just have to be aware of how long till the CYA gets out of hand. There is a drop down at the bottom of pool math that will tell you how much FC and CYA you will get out of a given amount of any chemical tablets included just put your pool volume and the weight of the tab in and it will do the math. Being at 40ppm CYA I would not use them often perhaps vacations only.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2015
    Fairfield Twp, OH
    216
    I like that all the responses were consistent!
    The guy that came to help me install a new skimmer line and new sand filter " he used to work for pool store, now does it as a side line" told me to put the puck in the skimmer basket. I didn't know it could cause problems. I have a floater for pucks but they seem to take for ever to desolve. I like the idea of hanging them in front of return. Thanks.
    I wish a knew a way to slowly release liquid chlorine.
    Jul 2015
    Central Valley CA
    1,107
    Quote Originally Posted by filix View Post
    STENNER pump...
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    The pucks are designed to dissolve slowly so that they dispense chlorine over the course of a week. They are intended to keep a little chlorine in the pool between weekly "shocks". If you test you pool daily and keep the chlorine at the top of the recommended range, you won't need to add pucks unless you want to use them when you are out of town.
    Love TFP? Become a
    TFP Supporter!
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Chemical Automation and The Liquidator
    You just need to poke around some of the other sections of the forum.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Thanks for the help.
