Results 1 to 7 of 7
Thread: protecting pump from leaves while away
    Aug 2015
    Philadelphia, PA
    18
    Going on vacation this Fall for 10 days. Not worried about chlorine since the SWCG produces enough with the pump running for 6 hours daily.
    We have (too many) trees near our pool, and the leaves were a significant issue last Fall. At the height of the problem, I had to clear out the skimmer baskets 1-2 times/day. We were away for a week last year, and the baskets were clogged to the point that the pump was sucking air.
    We have two drains at the bottom of the pool (one main drain and one for the water feature pump). I am considering turning off the skimmer drain lines and pumping exclusively from the main drain while we are away. Interested to hear from those with more experience if that is a good idea.
    1. I imagine that we will come back to a pool entirely covered with leaves. Will it be a problem to have that much organic material floating around the pool for that long? Should we consider aiming for a higher FC level?
    2. Is there a danger of having leaves sucked down and clogging the main drain (8 feet deep)?
    3. Would you recommend running both pumps (main drain and water feature) to keep water circulating?
    Thanks.
    31k gal, IG plaster, Hayward pumps and cartridge filter, AquaRite T-15 SWG, Hayward 400,000 BTU NG heater, TF-100
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: protecting pump from leaves while away
    Do you have a safety cover? You can put it on and leave the pool running under it.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Or even a solar cover would help a lot.
    Also you can put a milk crate over the main drain to keep leaves out. I've seen some people hang a milk crate over their skimmer for the same reason.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    I don't know how much "more" experience I have, but I'd think about covering the pool and running the pump less.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Aug 2015
    Philadelphia, PA
    18
    Quote Originally Posted by JohnT View Post
    Quote Originally Posted by RyanMcC View Post
    We have a safety cover, but it is a non-trivial project to install and remove it (large surface area, irregular pool shape, raised spa/wall). Was hoping to avoid by shutting off the skimmers.
    Quote Originally Posted by Mr Bruce View Post
    Interesting idea. I imagine that a milk crate could also get clogged, but it would have a larger surface area than the drain cover.
    Thanks!
    Jul 2015
    Central Valley CA
    1,107
    If you pin the weir door down with a shim or remove it if practical skimming should be greatly reduced, that with the crate idea should keep most if not all leaves out of it.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Plugging in a vacuum hose and either weighing down the other end or securing it (to a ladder, stair rail, etc) underwater should do fine to allow circulation without skimming.
