Thread: What is this red/pink stuff on walls?
    LoraT's Avatar
    May 2016
    Owensboro, KY
    38
    First year using the TFPC method - which is AWESOME!!!! I was cleaning the waterline with a microfiber cloth yesterday, when I noticed this weird "dirt", only at the deep end. I am posting photos which show what it looks like before and after wiping with the cloth, as well as the stain it leaves on the cloth after wiping. It is very difficult to get it off the walls - it just wants to smear. Is this pink algae? Has anyone ever seen anything like this? FWIW, here are my current test results:
    FC 6
    CC 0
    PH 7.8
    TA 90
    CH 250
    CYA 60
    12,000 gallon, in-ground, vinyl liner pool, TF-100 - City water
    Hayward Super II 1-Horsepower Pool Pump and Hayward Pro-Series S244T 24-Inch Top-Mount Sand Filter
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    49
    Re: What is this red/pink stuff on walls?
    I actually get that red smeary stuff inside the house, on the sink drains. I was told it was bacterial iron.... not sure if that's the same stuff you are experiencing. We have pretty hard, sulfury well water.
    22,400 gal; in-ground gunite rectangle, vinyl liner; 3.5'-8' depth; Chlorine; auto cover; Hayward Pump and Sand Filter; Hayward Electric Heatpro; diving board; 3 sidewall fountains; open mid May thru mid October; built 2011; Taylor K-2006C FAS-DPD Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, there is a thing called pink algae that is really a bacteria. As with most algae and all bacteria, maintaining chlorine above minimum for your CYA at all times will prevent it from getting a foothold. FC/CYA Chart. Now that it has moved in it is time to SLAM to kill it.
    LoraT's Avatar
    May 2016
    Owensboro, KY
    38
    I think you have confirmed what I already knew - but didn't want to admit . Guess I'll begin the slam in a little while. Thanks!
