Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 154
Thread: Green pool, SWG broken - advise on how to maintain pool until SWG is fixed.
    Guys, I'm reading and following along and in need of my own help.
    I have a Hayward SWG that is now not working and I'm waiting for a part to arrive. In the mean time my pool water (13k gallons) has turned green and continues to darken in color. I tried shocking it 7 days ago but it stays green. I've also ordered a test kit and waiting for it. What can I do in the meantime until the SWG is repaired and the test kit arrives?
    Thanks for your help.
    13,000 Gal (Est.) 14x28 pool w liner
    Hayward salt system - Aqua rite low salt
    Hayward Pro Series Filter
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Green pool, SWG broken - advise on how to maintain pool until SWG is fixed.
    Bleach, Bleach, Bleach....oh and circulate
    Do you know what your current Fc level is?
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Add 1/2 gallon of bleach every day with the pump running.
    Which test kit did you order?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    I don't know any levels. I'll get a pool company test and report numbers. Can I use chlorox from Walmart?
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Quote Originally Posted by trevsand View Post
    Eesh... we don't trust those numbers but its a start. Do you at least have an OTO? Good test kit on order (tf-100 or K2006)?
    Clorox is fine but great value is cheaper... Look for 8.25% on the ingredients
    13500 gal
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    I'd skip the pool store. Yes, chlorox is fine. Great Value bleach (8.25%) from Walmart is just as good and about $1 cheaper.
    I'm getting the tf100 kit.
    What's an OTO?
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    What's an OTO?
    OTO is a cheap tester from HTH... bought at walmart... Its basic function is to tell you if there is any chlorine in the water at all.. very unreliable
    13500 gal
    I did a pool shop test 7 days ago. Zero chlorine. I shocked the pool and then it turned cloudy. Then I realised swg is broken. I'll do a test tomorrow too.
    Guys, are you sure bleach is safe for my salt water system? Worried that it might destroy the equipment.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Believe it or not, guess what the G in SWG is Genereratin'?
    Chlorine!
    Haha, I figured but wanted to double check. Real newbie here. Thanks to everyone responding to this point. Hopefully we can figure it out.
    Guys, heres a picture of the pool. I added 1 gallon of Chlorox and am brushing 2x a day now.
    Should I be adding more chlorine and cya while waiting to fix my SWG and for my test kit to arrive?
    Is liquid bleach the best way to add additional chlorine?
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Stick to 1/2 gallon a day until your test kit arrives... then do a full blown test on everything you can and post the results so we can see what you have. Don't worry about cya until you have results. You definitely don't want to over shoot that one.
    Bleach is the easiest way to maintain chlorine levels othe r than your swg. It only adds chlorine and nothing else
    13500 gal
    Good morning all,
    I went to a pool store to test the water. Attached are the results.
    My SWG should be fixed by end of day today.
    I'll be adding 1/2 gal of bleach tonight.
    Should I be backwashing and brushing on a regular basis - like 2 or 3 times a day?
    Attachment 52829
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    If these results are accurate, which most pool stores are not, then you PH is too high, FC is too low, and CYA is too low... Bright spot is no CC... In reality, this may be their tap water...which is why we don't trust stores or pool companies...
    So, keep up with the 1/2 gal bleach daily until your kit arrives.
    Brush 1-2 times daily if your schedule permits.. Don't need to back wash until your pressure gauge reads 25% higher than normal. IF you don't know what normal pressure is, do about a 1 min backwash then note the new pressure when you move the selector back to filter.
    13500 gal
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Bleach is just a trade name. It is sodium hypochlorite. Just like picking up a box of store brand acetaminophen and not Tylenol. They have both the same active ingredients. The difference is price.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Ok, I think I'm ready for your help. Thanks in advance.
    SWG is up and running - its on SuperChlorinate and has been on for 5 hours now.
    I have the Taylor k 2006 test kit and these are the readings:
    Salt 2700
    Chlorine 0.6
    Ph - super high - looks like higher than 8.5
    Al - 160
    I'm still figuring out the kit but this is what I came up with.
    The pool is getting greener still though.
    What are my next steps?
    Thanks again.
  20. Back To Top    #20
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Chlorine up and ph down...
    Add enuf bleach to get chlorine up to about 5-7 then about 1/2 hour later add enuf MA to bring ph down to 7.5..
    Wait about an hour and test for both again. Need to get your ph in control before we really hit your chlorine
    13500 gal
