Thread: Need help Polaris pool vacuum that leans sideways
    Jun 2015
    summerville, sc
    2
    My pool vacuum, WALL.E, leans, runs in circles and will not cover all the pool. i have replaced tires which were worn and mushy. i have replaced ballast. What else should i do?
    Darla: SW IG FB Pool, 32.5 X 16, 9K gal, SuperFlo 2sp 1hp 355003S pump, Century hp booster pump, Intelliclor IC20, Cartridge filter CCP320, Pentair Kreepy Krauly Pressure Side Pool Cleaner, PAL-2000LAU color lock lamps. City water, Summerville, SC, installed 2010.
    Jul 2015
    Central Valley CA
    1,109
    Re: Need help Polaris pool vacuum that leans sideways
    You can adjust the tail pressure down a bit (adjustment screw near the base of the tail) if it is whipping excessively this will increase pressure to the bag and push the Polaris it down against the pool surface a bit more. Also you can remove the rear jet and rotate it 180 degree it will make the unit tend to turn the opposite direction can sometimes help.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2015
    summerville, sc
    2
    Thank you for your reply. i will try these changes and let you know how it works.
