Results 1 to 7 of 7
Thread: PB-4 Booster Pump STILL Leaking After Changing Seals
    Azriel928's Avatar
    May 2016
    Denham Springs, LA
    6
    Unhappy PB-4 Booster Pump STILL Leaking After Changing Seals
    I've been having issues with my booster pump leaking from the bottom (the small rectangle opening between the front volute and the motor). After some research I decided to change the shaft seal and o-rings as recommended. Pretty straight forward repair but after waiting an hour or so when I powered it on, it was still leaking a good bit from the same spot. Did I do something wrong or is there possibly another issue?
    In-ground 30,132 gallon / Vinyl liner / Hayward Sand Filter / PB4 Booster Pump / Polaris 380 / Pentair In-line Chlorinator / Taylor K-2006
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: PB-4 Booster Pump STILL Leaking After Changing Seals
    There should also be a gasket that seals the cover plate. Did you replace that too?
    Mark
    Azriel928's Avatar
    May 2016
    Denham Springs, LA
    6
    Forgive my ignorance, but if it wasn't in the kit that I bought, then no it wasn't changed. My kit contained:
    • Southeastern Brand O-Ring Replacement Seal Kit (Pre 2012) For Polaris Booster Pump 3/4 hp PB4-60
    • Includes: 1) Shaft Seal O-ring Replacement For O-30 P40
    • 2) Volute O-ring replacement For O-299 P95
    • 3) Pump Shaft Seal Replacement For PS-1000 AS-1000
    mas985's Avatar
    Pleasanton, CA
    11,737
    That should of had all the seals required. The only other thing I can think of is the seal was not installed properly.
    If there rust on the motor shaft, you can try to remove some of that with fine steel wool.
    The two matting surfaces of the shaft seal must be kept completely clean (absolutely no lube on those).
    Also, if the seals were not fully seated, it may leak.
    Mark
    Azriel928's Avatar
    May 2016
    Denham Springs, LA
    6
    Thanks for the information. I took the pump back apart again and after close inspection I noticed that I have a crack in my bracket. I'm pretty sure this is what was causing my original issue and then when I replaced the seals I probably cracked it more. I've ordered a new bracket but it won't be in until the middle of next week. How outlandish is it to try and repair the crack using some pvc 2 step repair or even a sealant? My pool is very green and on the verge of being a full blown swamp so the sooner I can start SLAMming, the better. I've attached a picture of the bracket with the crack.
    mas985's Avatar
    Pleasanton, CA
    11,737
    If you seal it on the inside where the pressure is, then it might hold for a little while.
    Mark
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Resurrecting this post.
    Azriel928, what was the fix? I seem to be having this same problem today after replacing the shaft seal.
    19k gal IG plaster, built '70s, probably resurfaced in '80s-'90s; Blue Haven Hayward filter C4520BHMB (Filbur FC-1275 cartridges); Hayward MaxFlo sp2302 VSP 1.5hp; 6 solar panels 288. sq. ft. total (142"x47.5" ea.) on 1 story hm; Pentair Compool LX220 Solar Controller; FlowVis flow meter; Maytronics Dolphin S200; AG 300 gal AquaTerra spa; TF-100 & Speedstir; gone: Pentair Challenger 3/4 HP 1 speed; Polaris 280
