Results 1 to 19 of 19
Thread: Newbie to doing pool chemicals -not holding chlorine/cloudy water..help!
    Jul 2016
    Canada
    6
    Hi!
    We've had a pool for 8 years and we've never had any problems. We did the 15 minute workweek kit and cleaned the pool without ever having issue. This year the pool has never been clear. It is cloudy all of the time. There is no green or yellow algae visible, but when I take a water sample, the pool doesn't hold the chlorine and I cannot see the bottom of the pool. I've tried to get local people to help, but they seem more keen on selling chemicals that never seem to rectify the problem. I am turning to this forum for desperate help! I will warn you that I will need step by step help because I have never done much with the chemicals before, my husband used to do that. Anyway, I sure would appreciate the expertise of the people on this forum. Here is my pool information:
    Volume: 72481 litres
    surface:Vinyl
    filter:Sand
    Type:Inground
    temperature: 21.11 Celsius
    Test Results
    Free Chlorine: 1ppm
    Total Chlorine: 1ppm
    Combined Chlorine: 0ppm
    PH: 7.2
    Hardness: 280 ppm
    Alkalinity (w/ stabilizer): 134 ppm
    cyanuric Acid: 20ppm
    Total Disolved Solids:1400 ppm
    It was recommended that I add Nu-Blu, which I did, but it didn't help.
    I would be so grateful for any help that you can give. Thank you so much!
    Dec 2014
    Santa Ana, CA
    523
    Re: Newbie to doing pool chemicals -not holding chlorine/cloudy water..help!
    Welcome!
    I'm not sure very useful Pool Math page from above can be switched to metric system. If it cannot you'd just need to convert back and forth using Google . Your pool volume is 19,000 gal, please put this and pump / filter model in your signature to help whoever helps you find it.
    TFP recommends 2 test kits for testing water: TF-100 or K2006. Strips or pool store results have proven to be inaccurate to be of any use. TFP recommends liquid chlorine (bleach) for chlorination almost exclusively. No solid form of chlorine is generally recommended due to its side effects.
    If you don't have either of the kits I'd place an order for one of them ASAP, it's impossible to do anything with the pool blindly.
    The rest of the process depends on if you can partially drain / refill your pool: sometimes it's more effective to drain severely imbalanced water instead of going through hoops trying to balance it. Just to keep you afloat I'd add 2 one gal jugs of 8.25% bleach to the pool and keep adding at least 1/2 jug of the same bleach daily until your test kit arrives. Bleach needs to be plain: not scented or splashless.
    As you can see you'd need to stock up on bleach (10 one gal jugs just to begin) and also buy 1 - 2 one gal jugs of Muriatic Acid (MA). Your pool store might even carry both with higher concentration. Please make sure you don't buy anything else there.
    Please do not add anything but bleach from this point on unless advised by someone from the forum and remove any chemical dispenser you might have from the water. TFP method requires commitment . When your test kit arrives please post back so the actual troubleshooting can start.
    Does your pump / filter work as expected? Was the filter cleaned recently?
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,265
    There are people here who are willing to help, provided that you commit to learning the TFPC system and do a bit of reading first. Your situation is very common and can probably be fixed with some initial effort. Once you get it fixed, TFPC is a very easy, predictable and reliable system, and will give you much safer and cleaner water than you thought possible.
    This thread is good opening reading (just the first page need be read): TFPC for Beginners
    You can't do TFPC without a reliable test kit, and sadly they're a bit more expensive in Canada. You will need the K-2006 kit (about $200) and I suggest ordering a 60 ml bottle of R-0871 FAS-DPD Titrating Reagent ($40) as well. Here is the order form: LowryCanadaResidentialOrderForm2016.pdf
    TFTestKits does not ship to Canada, but if you know someone in the US who would buy it for you and then forward it to you, then buy the TF100 with XL option and you can get started for half as much money. TFTestkits.net
    Get the test kit ordered right away. There is very little anyone can do with test strip or pool $tore results. You will save back the cost of the test kit by using low-priced readily available pool chemicals that the pool store will never tell you about. For a start on that, don't buy any more Pool $tore Potions.
    Am I sounding like a midway huckster? Yeh probably, but there's 1000s of threads here that start out with exactly what you said. And the ones that work out well get a test kit right away and follow TFPC methods quickly. By the way, I don't sell test kits or work for Taylor or Lowry.
    Required reading includes:
    "Read before posting" linked in my signature below. Following those instructions will get you the best possible advice here.
    And this one which gives the basics of pool water chemistry: Pool School - ABCs of Pool Water Chemistry
    And then please spend some time looking at Pool School and PoolMath (both linked at the top of every page).
    The articles are very concise and well written. TFPC is not all that complicated and we've all been in your shoes!
    I'm away for a few days, or I would help you out (I'm an expat Canuck), but there are many people here who understand your problem and can walk you through it if you decide to take charge of your pool. You'll never look back once you do!
    In the meantime, you need some chlorine in your pool to stop it from being unsafe or getting any worse. Canadian Tire has a good deal on Pool Chlorinating Liquid Aquarius Liquid Chlorine, 5-L | Canadian Tire, and you need to be pouring in about 1/2 gallon (2 litres) each day until you get your kit.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    needsajet's Avatar
    Jan 2016
    4,265
    Just want to mention that I don't expect a drain/refill will be needed, provided that the CYA reading you provided is anywhere near correct. When you get the test kit, we can make sure. PoolMath has a drop-down box in the upper right corner where you can switch it to metric.
    Please add your city and province to your location when you get a chance. Some people here might think Canada is all covered in snow by the end of August , but knowing which region helps with recommendations.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    HI! So nice to meet you! The above two posters have you covered.
    -get test kit
    -add 1 jug of bleach a day with pump running 24/7 until test kit gets there.
    -brush pool daily to get the yucky stuff into the water to be filtered out.
    Jul 2016
    Canada
    6
    Thank you so much to everyone who has responded with such kindness and support. I am feeling much better and think I can actually do this!
    I have ordered the TF100 with XL option! It will be about a week until it arrives. In the meantime, I will add the 1/2 gallon of liquid chlorine that "needsajet" has suggested -Aquarius Liquid Chlorine. I will also brush the pool daily, as "kimkats" suggested.
    Should I order the FAS DPD Titrating Reagent or Muriatric acid, or should I be getting both? Both were suggested by different gurus, I would just like to clarify.
    I plan to spend time reading the links you provided in this forum, so I can better educate myself! I may still ask some stupid questions, so please be patient. Once again, thank you for your quick and knowledgeable support!
    Ingound, Pool volume-19,000 gallons, Sand filter,Vinyl liner
    Manitoba-Canada
    North of North Dakota 😊
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,087
    The TF-100 has all the testing chemicals you need, no need to get a separate FAS-DPD test. They were trying to help you piece together a test kit if you had problems getting a TF-100 in Canada.
    Hold off on MA, you may never need it.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2016
    Canada
    6
    Ok, perfect! Thank you for clarifying, Mr.Bruce.
    Manitoba-Canada
    Eustis, Florida
    68
    Don't worry, this method is so easy you will be asking yourself how it could be this easy once you get it cleared up initially. I didn't know a single solitary thing about maintaining a pool last year and have had a perfect pool for more than a year using the TFP method.
    AGP 33' x 54" Lomart Verona, Approx. 27,300 gallons, Pentair cartridge filter/pump 2-speed, 1.5 hp, Dolphin Escape robotic cleaner.
    Jul 2016
    Canada
    6
    Thank you for your encouraging words, chip chip!
    I have been brushing and cleaning the pool twice a day and there is noticeable improvement in the clarity each day! I am embarrassed to say that the pool has never been brushed. Yes, I was ignorant to the needs of my pool, but I am starting to take control of it now. Once things are stable, I plan to brush it at least once a week (that was a recommendation that I read on this site). I have also added 1/2 gallon of liquid chlorine each evening, as recommended.
    Today I drove down to the States and picked up my brand new pool test kit -TF-100! I am excited to get started, tomorrow morning.
    Manitoba-Canada
    needsajet's Avatar
    Jan 2016
    4,265
    Great news Glad to hear you could get the TF100
    Jul 2016
    Canada
    6
    First readings:
    TC- .5ppm
    PH-7.2
    TA-130
    CYA-20? Really not certain that I did this accurately.
    Manitoba-Canada
    needsajet's Avatar
    Jan 2016
    4,265
    If it was my pool, I'd raise to 30 ppm CYA (use pool math with 'target' set to 30 and 'now' set to 20 to determine the amount needed)
    At the same time, get the SLAM started, per this article: Pool School - SLAM - Shock Level And Maintain
    Jun 2013
    South Florida
    118
    I agree, go ahead and target CYA of 30. Then, perform a SLAM as per the directions linked above. You'll be clear in no time.
    How is you filter pressure? Do you know what your pressure is when the filter is clean?
    Your FC is low right now. Once the SLAM is complete, you will always want to maintain the target FC as per this chart: Pool School - Chlorine / CYA Chart
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    Jul 2016
    Canada
    6
    Ok, to increase the CYA, it says I should add 247 oz of liquid stabilizer. Do I get that at the store, or what should I be using? Then I will start the SLAM.
    Manitoba-Canada
    Jul 2016
    Philly Suburbs
    27
    Quote Originally Posted by Canuck5 View Post
    I've had good luck with the Clorox brand granular stabilizer (liquid costs twice as much). You can find it at the pool store, but it's likely cheaper on Amazon (Amazon.com : Clorox Pool Garden). You could go ahead and start your slam while you're waiting for it to arrive. Double check your numbers though, 247 oz seems like 3-4x too much.
    22,500 gallon in ground pool with vinyl liner. DE filter. Taylor K-2006.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    You've been given great advice so far. The CYA test is a light sensitive turbidity test. You may have done it correctly, but just wanted to make sure you did it in full sunlight with your back to the sun.
    In the states, you can find CYA sold in Wal-Mart and home improvement stores under the keywords of "stabilizer" or "conditioner".
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    needsajet's Avatar
    Jan 2016
    4,265
    To raise CYA from 20 ppm to 30 ppm in a 19,000 gallon pool, PoolMath shows me 25 ounces (by weight) of granular stabilizer
    If I switch PoolMath to metric, I get 72,000 litres and 720 grams of granular stabilizer
    Here's the product: Pool Water Stabilizer | Canadian Tire
    And this article covers pool chemicals and methods of adding: Pool School - Recommended Pool Chemicals
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    You can put the stabilizer in a sock and hang it in front of a return or put the sock in the skimmer. Give the sock a squeeze a few times a day.
    Once it is dissolved you can assume that your CYA is 30 and use the FC target of 12. The more often you test and adjust FC using bleach will help speed up the process.
    Brush daily and backwash whenever your pressure rises 25% above the clean pressure. Sand filters work best when they are a little dirty, so don't backwash early.
    Let us know if you have any questions.
    Karen
