Thread: Intex ultra Leg blocks in ground
    Handymam's Avatar
    Jul 2015
    Fairhope , Alabama
    6
    Leveled ground and installed blocks using a transom laser level / receiver . I am assuming due to rain and the fish bowl I created (landscape /drainage part #2 ) one quadrant of my pool is higher ...which means that the block(s) (level with others ) are recessed in the ground ...a few could be about 2 inches . Concerned about the stress on the liner seam . Any advice ?
    Jun 2014
    15,008
    Re: Intex ultra Leg blocks in ground
    Whatever happens once the rains stops, make sure to level everything before filling. Not much you can do once it's full of water, and believe me, the pool's waterline will naturally tell you right away how good you did on leveling. When on a slope, always dig down to make level, never try to build-up a side. Good luck!
    Handymam's Avatar
    Jul 2015
    Fairhope , Alabama
    6
    Thank you ! I did ..so far do good ..except I had 2 legs slip off the supports .
    Jun 2014
    15,008
    Nice to hear things are improving for you. Have a nice weekend.
