Results 1 to 8 of 8
Thread: Test kit
    May 2015
    Jonesboro, AR
    32
    Test kit
    Can I buy refills of just what I need or do have to get the complete refill kit. Normally I only test chlorine and cya.
    18x36 Rectangle, 8ft deep end, 26k gallons, vinyl liner, Intellichlor IC40 Chlorinator, 1.5 HP Superflo Pump, Hayward Tigershark QC Robotic Cleaner
    May 2015
    Jonesboro, AR
    32
    Re: Test kit
    Nevermind, I guess the website isn't mobile friendly. I found what I needed.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    Re: Test kit
    Unless you are having to replace a lot of water, CYA levels should stay fairly level. Chlorine and PH are what I check the most.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    May 2015
    Jonesboro, AR
    32
    Re: Test kit
    Did more than normal cya testing the last couple of years due to all the gulleywashers we seemed to get everytime I turn around.
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Test kit
    How's your pH and TA??
    You really, REALLY only test the FC and CYA? What about the CCs??
    How's your water look?
    May 2015
    Jonesboro, AR
    32
    Re: Test kit
    Well, let's see. The last time I tested the water my results were: FC 7, CC 0, CYA 70, TA 90, PH 7.8. I do test these things. Just needed some refill on cya and thought I'd get R-0871 while I'm at it. I have been testing cya more than normal because last year and earlier this year I've had too much rain. Been having to dump alot of water seems like. Maybe I'm just being over cautious. Water always looks good.uploadfromtaptalk1470074554401.jpg
    Mar 2015
    Sugar Land , TX
    424
    Re: Test kit
    Bought my last bottle online here:
    Taylor Cyanuric Acid Reagent 16oz #R-0013-E
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Re: Test kit
    TFTestKits.net has all the Taylor refills, and ships very fast, usually same day.
    http://tftestkits.net/Taylor-K-2006-Refills-c5/
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
